Turn signal relay switch......
Old Jan 15, 2011 | 02:14 PM
gragner66's Avatar
Default Turn signal relay switch......
Where is it located? Im looking at getting clear bulbs that blink an amber color from superbrightleds.com. I talked to one of the guys there and he said i need a delay switch as well to go with the lights. Where is the switch located i have pulled all the larger type fuses in both boxes and still not found the one that controls the blikers
Old Jan 15, 2011 | 05:57 PM
sport30's Avatar
Banned
I dont know what you are looking for, the words you are using dont make perfect sense. The switch is on the steering column and has a built in speaker in it.
There is no separate relay for the turn signals, and there is no old fashioned flasher relay either. The turn signal are run entirely from a computer module called the GEM, general electric control module. It is behind the glove compartment on LHD cars.
Old Jan 16, 2011 | 06:05 AM
Thermo's Avatar
Veteran: Navy
Gragner, like was mentioned, the lights blink at a rate set by the computer. The flash rate will change a little based on the current load of the circuit. So, if the flash rate changes too much, you will end up having to add resistors to the circuit in parallel to the new bulbs to help draw more current and slow the blink rate back down. Some people have a problem with this, some don't. With your year car, it shouldn't be an issue except for maybe the computer seeing the lower current levels (due to the LEDs) and thinking that a bulb is burned out. This will cause a message to be displayed on the dash.
Old Jan 16, 2011 | 09:24 AM
gragner66's Avatar
thnx for the info guys ill order the bulbs and go with it from there. has anybody here got any bulbs from them or anywhere else and tried it....i saw a post on here somewhere with a guy that had replaced the yellow front bulbs with a chrome colored bulbs was a nice clean look
Old Oct 10, 2012 | 02:48 PM
caseoane's Avatar
HI gragner66, I'm trying to do the same thing on my 04 X-type and just came across this... were you able to figure out the indicators? Did you have to add the resistors? I've heard that those can burn, so I'm hesitant to put them in if I can just have LEDs and draw less current.
thanks!!
Old Oct 11, 2012 | 09:38 AM
gragner66's Avatar
You can go with just the led bulbs but it makes the blinkers flash quicker in the car. But the outside flashes normal. Makes the computer think a bulb is burnt out if resistors are not put in
Old Oct 12, 2012 | 09:50 AM
caseoane's Avatar
Cool, I'll try that. Thanks for the quick reply!
Old Oct 12, 2012 | 05:57 PM
gragner66's Avatar
Np
CaneCounsel007
Nov 13, 2015 09:05 PM
abonano
25
Sep 25, 2015 10:43 AM
Richard_gib
Sep 12, 2015 07:08 PM
tonyforman
Sep 10, 2015 07:23 PM
jaguarbill
Sep 5, 2015 11:43 AM
