Water in spare wheel well 2010 Xtype estate
Old Feb 10, 2016 | 05:16 AM
Perryman57's Avatar
Default Water in spare wheel well 2010 Xtype estate
Hi folks,
Anyone experienced water ingress in the spare wheel area of an XType estate?
Looked last week and had about 3 inches!
I have also noticed that the rear washer is not spraying water onto the rear screen. Wondering if anyone else has had problems with the tubing running to it? The pump is working fine and a slight dribble of water is evident.
Wondering if the water is leaking into the wheel well!
Before I start stripping internal body trim out any previous experience or comments would be helpful.
Thank you!
Charlie
Old Feb 10, 2016 | 07:06 PM
hlgeorge's Avatar
Maybe the rear washer hose is broken or come lose and is dumping the water into the wheel well.
Old Feb 11, 2016 | 08:06 AM
euanT's Avatar
Welcome to my world!! very common fault in the estates, watch your reverse sensor module in the wheel well, they are prone to fizzle if they get wet!! I tried everything I could think to stop the leak, but by consensus bought a new tailgate seal, problem solved!!
Old Feb 11, 2016 | 08:36 AM
DPK's Avatar
DPK
Drill a hole in the bottom..at least for the meantime the water won't pool..once you solve where the leak/water is coming from..you can then plug the hole with silicone.
Old Feb 11, 2016 | 08:43 AM
euanT's Avatar
No need to drill a hole, just push out a grommet in the floor of the well and keep for when you fix the leak!!
Old Feb 11, 2016 | 09:31 AM
DPK's Avatar
DPK
Even better...I didn't know there was a grommet plug...good call.
Old Feb 12, 2016 | 04:17 AM
Perryman57's Avatar
Yes that's my first thought. Looks like an interior strip down to check. Thank you
Old Feb 12, 2016 | 04:20 AM
Perryman57's Avatar
Yes there are actually six grommets in my spare wheel area. One is out to drain water until source of water ingress dealt with. May be rear washer feed pipe broken or perhaps the tailgate seal. I'll start with washer pipe as clearly there is a problem there anyway. Thank for responses guys.
Old Feb 12, 2016 | 07:36 AM
Perryman57's Avatar
Yes I think you may have the answer. Will investigate whether rear screen water feed pipe is the problem first as a smaller job to fix. Thank for the reply.
andrew.hogan913
Feb 19, 2016 04:18 PM
scuby
XJ40 ( XJ81 )
Feb 15, 2016 08:46 AM
flyingfarmer
Feb 14, 2016 08:48 AM
Xj6s2tas
Feb 11, 2016 01:49 PM
sg18438
Feb 10, 2016 12:54 PM
