x type fan
Old Jul 15, 2014 | 07:46 AM
kp salted's Avatar
Default x type fan
Hi I have an x type 2.5 2002
Recently my engine management light has come on and I have noticed the fan now has gone in to some sort of safe mode as it comes on way more then it used too. The temperature gauge is always in the middle and the car never over heats so I'm confused on which component is causing the problem.
Plus the car will only blow out hot air when the foot is on the accelerator other wise when sat idol at lights blows out cold.
Any suggestions?
Old Jul 15, 2014 | 07:48 AM
Welcome to the forum kp salted,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Jul 15, 2014 | 08:31 AM
Thermo's Avatar
Veteran: Navy
kp salted, did you recently have any freon added to the car because of a poor cooling? If you have, it is very possible that what you have happening is the freon system is reaching too high of pressures and the system is shutting down to prevent blowing out a pipe. As the motor RPM comes up, the pressures inside the system rise and if they get too high, the system protects itself (ie, compressor doesn't pump and no freon is doing the cooling).
If this is not the case, then I am a little confused as to what is going on. If anything, you should be getting more cooling as you are driving down the road.
Old Jul 15, 2014 | 10:05 AM
kp salted's Avatar
No I haven't, I have had the car over a year and never needed to top up as the air con works fine.
Old Jul 15, 2014 | 10:08 AM
kp salted's Avatar
I am saying when I want to warm the car up in the morning even with the temperature turn up high the air will still come out cold when the car is stood still even when it has been running for a while but as soon as I put my foot on the accelerator warm air will come through
Old Jul 16, 2014 | 07:10 AM
Dr dome's Avatar
Is the secondary fan turning on when your ac is on? Meaning are both fans running when yourac is on?
Old Jul 17, 2014 | 05:49 AM
kp salted's Avatar
I haven't looked I'll have to look and get back to you thanks
Old Jul 17, 2014 | 10:49 AM
Cherry_560sel's Avatar
Sounds like a heater core problem. My impala did the same thing. At stop and go traffic in the winter, it was areal problem. Replaced heater core and problem is fixed.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Holden
Sep 5, 2015 03:29 AM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
