X Type 'HOW TO' " quick links " model specs / info / accessories
Old May 4, 2008 | 09:58 PM
Exclamation X Type 'HOW TO' " quick links " model specs / info / accessories
Please see below all FAQ's currently available for the X type section.
Please advise as and when any info worthy of addition becomes available and I will gladly update them.
Jaguar_EPC_electronic_parts_catalogue
https://www.jaguarforums.com/forum/g...9/#post1161835
https://www.jaguarforums.com/forum/g...6/#post1161325
Accessories(links to these 3 documents are broken - GGG)
2006 Accessories
2006 Sport Collection
2007 Accessories
Audio
premium audio upgrade
How-to-remove-cassette-player
removing-headunit
radio-removal-instructions
retro_fit_OEM_amplifier
Autolock feature
disable_autolock_feature
Brakes
complete-brake-pad/disc-and-fluid-change-c/w-pics
brake-pads-rotors-calipers-all-posts-in-x-type-section
EBC-brake-pads-discount
Brochures(links to these 2 brochures are broken - GGG)
2005 Estate
2006 Models
Color Codes (paint)
Exterior
Downloads
Assorted Tech files
Electrical
electrical_diagram
Engine
engine_oil_drain_plug_location
oil_pan_gasket_removal/renewal
Oil pan gasket and rod bearing renewal with pics
Thanks to gkubrak
engine-removal-thread
3.0_engine_removal_and_rebuild?c/w_pics
k-&-n-filter-replacemets
03-X-type-coolant-replacement
split_air_hose_/_leak_-fix
compressor_removal
ambient_air_temp_sensor_replacement
How To Drain Transmission Fluid
Replacing Spark Plugs
https://www.jaguarforums.com/forum/x...ted-faq-62847/
https://www.jaguarforums.com/forum/x...up-pics-63215/
https://www.jaguarforums.com/forum/n...s-xtype-83457/ (thanks the magicjuan17)
Fuel flap
fuel_flap_replacement
spark_plug_change[/B]
Fuse Box
Fuse Box Diagram & Information
Grille / Bumper Removal / Park aid Diagnosis
upper-mesh-grille-insert
park_aid_diagnosis
park_aid_diagnosis
front_bumper_removal
Headlights / bulbs
definitive-how-to-for-HIDS-in-the-fogs
headlights-bulbs-HIDS-all-posts-in-x-type-section
hazy-headlight-remedy
HID'S_in_the_fogs
Interior
overhead-console-removal
paint-code-locations
one-touch-windows-reset
step-by-step-door-panel-removal
Steering-wheel-removal-&-reinstallation
how_to_replace_bulbs_in_vanity_mirrors
buzzing_behind_dash
no_radio_info_after_replacing_battery
https://www.jaguarforums.com/forum/x...ts-leds-58115/
https://www.jaguarforums.com/forum/x...-heated-64668/
Key Fob
Key_fob_facts_all_you_need_to_know
Reprogramming-key-fobs
Sat Nav
Latest_Nav_disc_X_/_XJ_/_S_type
Speedsensor ring
rear-wheel-speedsensor-ring-failure-diagnosis-&-replacement
Transfer case / Diff / propshaft
transfer-case-oil-change
how-to-flush-and-check-fluid-level-auto-trans
Diff-oil-change
transfer_case_leak_from_the_vent
greasing_propshaft_centre_support_bearing
cold_weather_propshaft_whine_fixed
Various and Useful
JTIS21 CD Download and install thread (thanks to Jim Lombardi)
JTIS-download
squeeky-steering-cured
Steering Wheel - Center Bolt
seasonal-car-care
replace-key-fob-battery
x-type-owners-guide-on-pdf
Chassis-codes-C0000-C1788
Jaguar-guides
useful-pdf-files-for-x-type-various
Chassis-codes-C0869-C2767
handbook_download
A_MUST_SEE_FAQ_showing_how_to's/links/pdf_files_specs_etc_etc
P_codes_P1000-P1882
maintenance-sheet-log-x-type
Training Program
Sedan Introduction
Power Train
Technical Guide
2005 Model Updates
How To Fix Door Latch
https://www.jaguarforums.com/forum/x...-2006-a-57147/
https://www.jaguarforums.com/forum/x...r-i-faq-66224/
Please find below a list of files that will help you to decode your VIN numbers and also help identify your engine, paint, and trim combinations together with control module locations for your car.
Special thanks go to xjrguy for supplying the files.
Daimler Limo.pdf includes Hearse
Series III_en.pdf
X100_en_2000-02_US.pdf XK8 & XKR 2000 MY
X100_en_ROW.pdf XK8 & XKR ROW
X100_en_US.pdf XK8 to 1998 MY
X103_en_US.pdf XK8 & XKR 2003 MY
X150_en_US.pdf New XK range 2007 MY
X200_en_US Part1.pdf S Type
X200_en_US Part2.pdf S Type (shows trim/colour combo’s
X250_en_US.pdf XF
X300_en_US.pdf 1995 to 1997
X308_en_ROW.pdf 1998 to 2000
X308_en_US.pdf 2000 to 2003
X350_en_Final_US.pdf 2003 to 2010
X350_en_US.pdf 2003 to 2006 rough road markets
X351_en_2010 on.pdf XJ 2010 on
X400_en_US.pdf X Type 2001 to 2006
XJ40 a_en_US.pdf 1987 to 1992
XJ40 b_en_US.pdf 1993 to 1994
XJS_en_92 on_US.pdf 1992 to 1996
XJS_en_thru 91_US.pdf to 1992
Jaguar Vin Decoder.pdf Explanations
Some other VIN related tools:
Auto Calculator Site VIN DECODER (enter your VIN and decode).
Xclusively Jaguar site (scroll down the page for links to various models) Shown as a chart
Wheels / Rims / Tyres / Offsets
rims-tyres-wheel-offset-all-posts-in-x-type-section
how-to-refurb-your-own-alloys-cheaply
wheel and tire-standard-fitment-guides
X_type_vehicle_maintenance_sheets_petrol_&_diesel
[b]Workshop Manual in PDF. (thanks to LCGI)
Jim
Attached Thumbnails X Type 'HOW TO' " quick links " model specs / info / accessories-car01.jpg
stanjag
Dec 29, 2024 08:26 PM
fast40driver
Apr 19, 2024 07:24 AM
detXJ
May 22, 2016 10:50 PM
Stuart S
Aug 29, 2015 11:37 AM
Robgodius
Aug 25, 2015 09:34 PM
