09 xf power window issue
Old Oct 14, 2018 | 06:17 AM
09xf378's Avatar
Default 09 xf power window issue
Hello, I have a 2009 xf , I have a problem with my power windows not rolling up or down from the drivers master switch / main switch , nor with the left rear door window roll up or down but the passage side both work fine , I m trying to fix myself but no luck so far, I removed drivers door panel and replaced the window switch but still no luck , has anyone seen this issue before ,or can anyone point me in the right direction, I know this car has window modules but not sure if that's the next thing to try hate to keep replacing parts if I m going down to wrong path try to fix this so any help would be greatly appreciated thanks in advance
Old Oct 16, 2018 | 10:18 AM
Wurzel's Avatar
It is more likely the window regulator and the cables have broken, you can get repair kits but I would just get a replacement regulator they are around £140 or $180 us. There is a guide how to do it Youtube. Keith
Old Oct 16, 2018 | 08:39 PM
09xf378's Avatar
I m not sure but I don't think is the regulator because none of the windows work from the drivers master switch no noise or anything
Flstfi
22
Sep 12, 2025 05:07 AM
DrkNyte
Jul 29, 2017 02:23 PM
RFXJ12
Nov 8, 2015 02:11 PM
Leichardti
Sep 6, 2014 04:35 PM
blackforrestperformance
Nov 9, 2011 03:04 PM
