2008 XF Indicator issue
My XF shown a indicator bulb failure which I replaced, I looked at the old bulb and it looked fine but still replaced with a new one. I tested it working refitted the headlamp and fine for about 10 mins, took the headlight out again checked the bulb and its fine, cleaned the pins on the holder and the main wiring block tested working replaced and same again. Only this time as soon the car moved bulb failure came up again I checked the main block was seated correctly tested working as soon as I move bulb failure. I know this means a loose connection or short, is there any point in the loom that is prone to chaffing or shorting. Or am I looking at this from the wrong view point. Many thanks
PS. It's the offside front Indicator that's the problem.
metalmarty
Sep 11, 2015 07:05 AM
