2008 XF Indicator issue
Old Feb 16, 2014 | 08:22 AM
Mark8's Avatar
Unhappy 2008 XF Indicator issue
My XF shown a indicator bulb failure which I replaced, I looked at the old bulb and it looked fine but still replaced with a new one. I tested it working refitted the headlamp and fine for about 10 mins, took the headlight out again checked the bulb and its fine, cleaned the pins on the holder and the main wiring block tested working replaced and same again. Only this time as soon the car moved bulb failure came up again I checked the main block was seated correctly tested working as soon as I move bulb failure. I know this means a loose connection or short, is there any point in the loom that is prone to chaffing or shorting. Or am I looking at this from the wrong view point. Many thanks
PS. It's the offside front Indicator that's the problem.
Old Feb 16, 2014 | 10:18 AM
Mark,
I've moved your question from General Tech Help to X250 (XFR/XFR) forum.
Members here with the same model will be able to help.
Dz1rfj
Sep 16, 2015 03:44 PM
metalmarty
Sep 11, 2015 07:05 AM
Oldbill1
Sep 10, 2015 10:24 AM
Saturbo
Sep 8, 2015 07:35 PM
Mosers63
Sep 6, 2015 02:53 PM
