2010 xfr, p0236
Old Jul 31, 2014 | 05:24 PM
Dache's Avatar
Default 2010 xfr, p0236
I'm recently having the P0236 fault code pop up on my 2010 XFR. After 5 or 6 restarts, it'll clear on its own. Any ideas on the specific issue that might be happening?
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
Old Jul 31, 2014 | 06:36 PM
lotusespritse's Avatar
You don't even have a turbo...
Old Jul 31, 2014 | 06:38 PM
Dache's Avatar
Right. It's a boost sensor of some sort. I think the title is a generic code, so it would relate to the supercharger.
Old Jul 31, 2014 | 08:34 PM
Dache's Avatar
Yarg... Found it. MAP sensor is dead. Intake has to come off to get to that one. This should be fun.
Old Aug 1, 2014 | 01:46 PM
tbird6's Avatar
Thanks for reporting back! It always helps the next guy.
Are you going to change the MAP? It would be a great write up if you did?
Old Aug 3, 2014 | 10:54 AM
CP1's Avatar
CP1
I had this code a week ago (2011 XFR). It cleared up on itself and hasn't come back (yet). I have a Bluetooth OBD II reader and cleared the memory codes from my phone.
BTW, how did you determine the MAP sensor was dead?
Old Aug 4, 2014 | 03:40 PM
Dache's Avatar
The code comes and goes. I just received a recall notice for the jag due to another emissions related code. Might have that fixed first and then see if I still get the code. If it doesn't I'll probably look to replace in October when it's not 110 degrees outside.
I have a wifi OBII scanner to pull / erase the codes. Can't beat a $16 hardware device from China and a good iOS app!
Old Jan 12, 2016 | 03:02 AM
alexander07851's Avatar
Hi. Did you solve this problem? I have the same one
Old Jan 12, 2016 | 08:40 AM
LegendaryV's Avatar
I tried for about 12 hours to get to the MAP sensor and was never able to get to it. I put it all back together and bit the bullet to take it to the dealer. Ended up just being a vacuum leak. DOH!
I think I have another one now though as the car is running pretty rich.
Old Jan 13, 2016 | 04:25 AM
JagV8's Avatar
OBD tool, live data, watch fuel trims... see the many posts about this / how / what etc.
Old Feb 5, 2016 | 05:06 AM
Where was a vacuum leak? I've already changed MAP and MAPT sensors but P0236 appears again I hate it)
Old Feb 9, 2016 | 11:28 PM
LegendaryV's Avatar
i don't know specifically as I ended up taking it to the dealership. My understanding from them was that it was the main gasket on the supercharger.
Old Mar 8, 2016 | 11:41 PM
JBzXJ40's Avatar
Shouldn't have to take the intake off. It's in the back below the throttle body, should be fairly easy to get to. Take the intake off pipe off, remove the throttle body, and it'll be just below.
Old Mar 9, 2016 | 04:40 PM
JBzXJ40's Avatar
Sorry I got mixed up, was thinking about the 4.2L, you should have the 5.0L, that being te case, I believe there are 2 map sensors, one in the front next to the throttle body, and one in the back. Being its an XF, there will be less room to get to it, but it can be done with some patience if you take the wiper arms and cowling trim off.
Rocky15
Oct 12, 2015 03:42 AM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
ChrisJay
Sep 27, 2015 09:08 AM
