AC issue
Old May 3, 2019 | 02:33 PM
Supercharged81's Avatar
Default AC issue
AC not blowing cold, 2010 Jag XF Supercharged. Once i turn the AC to lowest setting air gets cold, and then i adjust the temp. It will then continue cooling/running as it should. Could this be the direct pressure sensing valve failing? Many thanks.
Old May 18, 2019 | 04:41 PM
lotusespritse's Avatar
I’d be interested to hear if anyone has had their pressure sensing valve replaced?
https://www.google.com/amp/s/www.car...1420681139395/
Old May 18, 2019 | 04:57 PM
It is going to the shop next Friday. Now that it is getting warmer outside here is what I have noticed with the AC. It will cool, but it is slow to cool. Will eventually end up w cold air from vents, but taking longer than it should.
Old May 18, 2019 | 05:06 PM
Interesting.
On both my Jags, only on occasion, the A/C will blow warm for the first 2 or so miles, and then blow nice and cold for the rest of the trip. And it's pretty rare to do that on my white one. Maybe a couple times since we got it in 2011. On the grey XF, it's done is a few times in the past couple of months of daily driving. All other times the AC blows cold from the get go, and always does a good job.
It seems like that could be an intermittent sensor issue.
Old May 19, 2019 | 07:37 AM
kiddhan625's Avatar
Interesting.
I have also been experiencing the same this past month. It will blow warm air while in park but once I get going it will slowly turn into cold air.
Old May 19, 2019 | 09:07 AM
Gus's Avatar
Gus
I experienced a on and off issue with my 2010 XF A/C and I took it to Jaguar and they fixed it. What they said was that the A/C was over charged. They drained the system then recharged the system using the weight of the coolant and not the pressure readings we are so familiar with.
Gus
JagRepair.com - Jaguar Repair Information Resource
Old May 19, 2019 | 09:27 AM
Gus
Someone must have bought a can of the DIY refrigerant with the silly little gauge on the bottle that makes you think you're an expert A/C mechanic.
If you find yourself standing in front of those cans wanting to buy one, you know you're about to make things worse. Most of them contain stop leak, which never stops a leak, but has been known to f-up the entire system.
Life has definitely changed. Modern car AC systems have a very small margin for error on amount of refrigerant, either too much or too little, but most people don't know that because the cars from the 70's and 80's weren't so sensitive and they think they are the same now.
Old Jun 5, 2019 | 02:52 PM
Supercharged Jag's Avatar
Interesting.
Did you ever find the solution? On my 12 XJ, I'm having the same issue as you described. The first couple miles or when it's idling it blows warm air. I thought it was low on refrigerant, I got it recharged for $130. Turns out that wasn't the issue, it's still blowing warm first couple miles. Reading all the complaints regarding the Direct Pressure Valve, I ordered one for $135. Now seeing your replies as well as others on this post describing the exact issue is giving me second thoughts to the Pressure Valve replacement.
Old Jun 5, 2019 | 04:41 PM
The local shop I took it to claimed they could handle checking the AC system on a Jaguar. It turns out they were clueless on JLR vehicles and identified nothing. The vehicle is going to the local Jaguar dealership this Friday. I will post results as soon as I find out. Be aware there is a TSB that covers 2010 to 2016 for the Direct Pressure Sensing Valve as it must be prone to failure. TSB JTB00380NAS4
Old Jun 6, 2019 | 11:28 AM
deanmartini's Avatar
My XF-R is doing this as well. I'm going to have the dealer check it out.
Old Jun 10, 2019 | 06:22 PM
AC issue resolved. Jaguar dealer confirmed my AC issue was indeed due to the failure of the direct pressure sensing valve. Work was performed under the previous mentioned TSB, consistent cold crisp air has returned. 450 dollars to sort out.
Old Jun 11, 2019 | 05:59 AM
Gus's Avatar
Gus
On the road again.
Gus
Old Jun 11, 2019 | 10:31 AM
That's good to hear. And not a bad price for the work. The TSB says the compressor has to be removed to change the sensor. If that's the case, I am just going to DIY and just put a new compressor since I can buy a complete kit with new sensor and dryer for around $400.
https://www.coolairparts.com/index.p...roduct_id=4155
I just did a compressor change on my Lamborghini, so any other car will seem easy compared to that one!
Old Aug 2, 2019 | 12:38 AM
Tomy49492's Avatar
I have the same issue. Turns out my cooling fan is runs super low or the coming on. Got the fan on 100% ac super cold. Now gotta figure out way the fan is not turning on right
Old Aug 2, 2019 | 12:44 AM
That seems like you have a different problem. On mine, it will blow warm as if the compressor is not running at all for the first couple of miles, despite how fast I am going. So it's not fan dependent. And then it will blow great the rest of the trip even if I am in stop and go traffic where the fan has to do all the work for the A/C to function. If I had a fan problem, it would still blow cold when I am going fast at the beginning, and it wouldn't blow cold when I was stopped.
Old Sep 9, 2019 | 10:35 AM
PJ704's Avatar
My issue is sort of similar to you guys. When I start the car, I have to let it set for some time (could be 5-10 minutes) before it gets cold. Also, sometimes I have to turn off the engine and then turn it back on and then it will start to get cold. Is this the direct pressure sensing valve?
Old Aug 31, 2021 | 03:39 PM
Swagger XC's Avatar
There was a #24 code, but I cleared it and drove for a week and the system continued showing no faults despite blowing warm. Compressor kicked on normally, etc.
MilitaryMan33
Aug 15, 2014 07:24 PM
BlackMac
Jul 3, 2014 04:16 AM
WinterJag
May 18, 2012 12:38 PM
SeldomJAG
Oct 11, 2011 12:21 PM
Jpetreeko
May 20, 2011 07:14 AM
