check engine light intermittent
I have a 2009 supercharged Jaguar xf. The check engine light wll come on then after several restarts go off. The code says it is the MAF, but we have already had this changed. My husband has reset and cleared the warning light but I continue to have it come on then go out after restarting 3-4 times. Why does it do this? Is there something we are missing?
Thanks Reddeb
Thanks Reddeb
Could be an air leak under the intercoolers if that wasn't previously repaired while under warranty. There's a foam gasket that leaks. Unfortunately, it can be expensive to get at because the intercoolers have to come out to fix this.
The light is back on. It seems to do it at regular entervals. Guess I'll take it in for a mechanic to look at if this keeps up.
There doesn't seem to be any issue with the way it runs. Thats good.
Thanks again!
Thanks again!
BrentGardner
29
Dec 16, 2024 12:13 AM
