Drivers door won't unlock
Old Apr 22, 2014 | 01:43 PM
WSD111's Avatar
Default Drivers door won't unlock
The drivers door on my XF won't unlock. I have used the key fob and keyless entry modes and it will not open. All other doors are ok.
Any thoughts?
Old Apr 22, 2014 | 02:07 PM
nasa25's Avatar
Door lock actuator probably needs to be replaced
Seems like front left door latch is jaguar part number c2d5640
Old Apr 22, 2014 | 03:17 PM
WSD111's Avatar
Looks like it's off to the dealer. Had it on its first big run over the weekend. Did 1000 miles and it went like a dream. Teething problems I guess.
Old Apr 25, 2014 | 02:10 PM
Jocelzy's Avatar
Angry Doors won't Unlock
Seems to be contagious then!
I clicked onto the keyless entry pad and heard as if they activated/unlocked, when i pulled onto the drivers door it wouldnt open/unlock!
I clicked again, tried the rear drivers side door, and it wouldnt open! Standing there with my evening meal in hand, I tried the barrel in the door and turned could hear as if it was trying to unlock but didnt, so I went around to the passenger side and luckily the passenger door would open!!
Reached across, pull the drivers door handle and it opened for me!
Today I tried to open the drivers door and ended up crawling across to the passengers side to get out!
Is there a ways I can pull a fuse to eliminate them from locking automatically till I can find someone to repair this?
Old Apr 28, 2014 | 03:09 PM
WSD111's Avatar
Smile
1 hour at the Dealers this morning and we now have a drivers door that opens from the outside too!
Old Apr 28, 2014 | 04:25 PM
nasa25's Avatar
Was it the actuator?
Old Apr 29, 2014 | 10:55 AM
WSD111's Avatar
Angry
Hi Nasa25
Apparently it was just an adjustment on the door mechanism. BUT although it worked well yesterday, today we are once again locked out. So back to the dealership again
Old Apr 29, 2014 | 12:36 PM
nasa25's Avatar
Is it under warranty? If so they should just replace the lock actuator and see if that sorts it.
Old Apr 30, 2014 | 10:22 AM
WSD111's Avatar
Yep under warranty. Just 1 month old.
Had door lock problems with the last couple of cars. My Audi A4, LR3 and my daughters Cruze. All brand new cars.
The previous car I had was a Ford Explorer (new) and doors were fine. Mind you the power steering did fail.
Its in with the dealer today and they assure me that it will be fixed. Lets hope.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Bigvettefreak
Sep 6, 2015 04:27 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
