Electrical gremlins and strange engine sound start up - Help!
Old Jun 30, 2015 | 03:48 AM
yazooo's Avatar
Default Electrical gremlins and strange engine sound start up - Help!
Hello all.
I have a 2010 XFR, V8 5.0 SC. Low mileage.
First issue, and most important is that the car has developed a very strange sound when pressing the ignition, almost struggling to come on. I have attached a recording of when I press ignition which I think highlights it well. Is the starter motor on the blink perhaps?
Second issue is electrical gremlins, particularly warnings every now and then on the drivers console screen, always after starting up. Typical warning is blind spot monitor not available, but now and then I also get some others at the same time like Adapative Dynamics Fault and an E-Diff one. The only correlation to when these occur is when the car has been out in the sun and warmed up. Bearing in mind ambient temperature where I am at the moment is 40-45 deg c so the car gets really hot if in direct sunlight for long as it is black.
Thirdly, is the drivers side reading light randomly comes on and off which is most annoying, especially driving at night. Any hints on these issues?
Service centre out here (Oman) are not known to be the most qualified so if I have some ideas in hand with which to guide them to solving the problems would be most helpful!
Attached Thumbnails Electrical gremlins and strange engine sound start up - Help!-20150610_201015.jpg   Electrical gremlins and strange engine sound start up - Help!-20150610_201027.jpg
File Type: mp3
Old Jun 30, 2015 | 04:30 AM
OzXFR's Avatar
Most of your symptoms suggest a battery on the way out, very common on a 5 year old XF.
Old Jun 30, 2015 | 04:58 AM
yazooo's Avatar
Thanks didn't think of that. Will see if the garage can check it.
Old Jun 30, 2015 | 09:21 AM
jagular's Avatar
Reading light fault is known. Assuming you're not accidentally triggering it when reaching for the rear view mirror (don't laugh, some of us have discovered this "fault" ) then a new unit is the fix.
I agree the battery should be properly tested, either load tested or with one of the fancy new digital testers.
Old Jun 30, 2015 | 11:01 AM
yazooo's Avatar
Thanks, I'm booked in tomorrow with the local Jaguar dealer. Hopefully they test the battery.
Any ideas on costs of a replacement?
Old Jun 30, 2015 | 05:55 PM
jagular's Avatar
Not where you are. Here a good brand of battery would be around CDN $ 150 I would guess.
Old Jul 1, 2015 | 10:32 AM
yazooo's Avatar
You were indeed spot on. The batter was on the way out. Thanks!
Old Jul 1, 2015 | 12:16 PM
Gpalace's Avatar
Did that sound go away at startup ? ...very odd.
Old Jul 5, 2015 | 11:52 PM
yazooo's Avatar
Thanks everyone. Picked her up yesterday from the garage. Battery changed, and some re-wiring done on the driver's ceiling light and she's feeling much better. 3 year warranty on the battery, bit pricey, about 150 GBP but that seems the going rate for imported parts like this out here.
BrentGardner
29
Dec 16, 2024 12:13 AM
hafren
Aug 30, 2023 03:42 PM
Drew2006
Nov 24, 2015 11:14 AM
1964Daimler
Sep 2, 2015 11:41 PM
dpappyp
Aug 27, 2015 06:31 AM
