FUEL PUMP RELAY, p0232
Old Feb 18, 2020 | 01:00 AM
TAEWOO KIM's Avatar
Default FUEL PUMP RELAY, p0232
2012 JAGUAR XF 5.0
first, I heard a lots of electrical noise above glove box before engine start, but soon it cover the sound because of engine sound. Is it normal to happen?
Secondly, While I was driving engine stop suddenly without sign, so I stop my car on side street to restart the engine but the engine didn’t back on. Then I checked the car if there is anything wrong, and found that fuel pump relay was heating up. So I plug off the fuel pump relay to cool off then put it back then engine was start up again. Since fuel pump relay was the problem I bought new relay to switch over but still there is problem plus no error code show (only show as OBD; P0232 fuel pump secondary circuit high) and no engine light
If electronic wire shot parts are problems, I don’t know which order to fixed or check out the problems. I was think to going to auto shop but I can’t trust them either.
Old Feb 18, 2020 | 12:07 PM
davetibbs's Avatar
Check your fuel pump fuse in the trunk (Fuse 25).
Old Feb 18, 2020 | 04:14 PM
TAEWOO KIM's Avatar
fuse is all fine
Old Feb 18, 2020 | 05:03 PM
davetibbs's Avatar
Next thing I'd be checking is wiring to the pump then. There are 3 fuel pumps on your car, an electric one in the fuel tank, and then 2 mechanical high-pressure fuel pumps on the side of the engine that are driven off the camshaft. The most likely suspect is the electrical one in the tank so the first thing to do is to get access to it - remove the rear seat bottom by finding the plastic levers underneath and pushing them towards the center of the car, this will let you raise the cushion. Pop off the cover behind the passenger seat and you should see the wiring to the fuel pump and level sender. Check that this plug is in firmly, you could also unplug it and check that you're getting a voltage to the pump with a multimeter, looks like pins 3 and 4 according to the wiring diagram but they'll probably be easy to spot with thicker wires.
Can you hear the pump run when you turn the ignition on or try to start the engine? If not, and you're getting +12v to pins 3 & 4 of the fuel pump connector, then I'd suspect a faulty fuel pump. Pain to change as it's held in with a ring that (on my car at least) required a special tool to remove, although some have apparently got theirs off with a hammer and screwdriver.
Old Feb 19, 2020 | 12:48 AM
TAEWOO KIM's Avatar
thank u
I will try this
Old Feb 28, 2020 | 02:51 PM
정연옥's Avatar
Old Feb 28, 2020 | 02:52 PM
정연옥's Avatar
Old Feb 28, 2020 | 02:55 PM
정연옥's Avatar
lubricant cleaning
Old Feb 28, 2020 | 08:06 PM
davetibbs's Avatar
Nicely found!
jag-reflex
Apr 25, 2019 02:10 PM
leo_denmark
Apr 19, 2018 01:42 AM
doug powell
Jun 26, 2015 07:37 PM
cooke
Mar 28, 2012 05:41 AM
daboss085
Mar 7, 2012 02:36 PM
