Has anyone replaced cats?
after alot of back and forth with dealer, finally got them to test alot of stiff and finally its the cat..
they tested a whole Lotta stuff relayed to the 0420 codes etc and yes its the driver side(bank2) cat that needs replacement.
problem jaguar wants like 1800 for it plus labor HA!
online several direct for were avaliable for 340 plus but for some reason they are all pit of stock all of a sudden and with the lockdown alot of places said they have no clue when they will get more stock of even...
anyways got some magnaflow universals...
problem is the ends of our converters are curved which is kind of wierd and never seen then in any car. several exhaust shops didn't really wanna cut and weld the universals on.
has anyone cut and weld the cats with universals and was there any problem?
thanks for any info
thanks for any info
from a small city and basicaly they will only do mufflers and the occasional weld here and there
yea need to find a good shop
thanks again
Well worth it, and way cheaper than going with OEM. You just need to find a decent muffler shop or performance shop, but should be straight forward
You can definitely weld in aftermarket CATS, see link: 300 CEL High Flow CATS..
well i was able to find a direct fit bolt on drivers side which is the 1 i needed but with the universals i was just gonna do them both
but well hopefully the pass sode doesn't give out anytime soon
thanks for the info and links!
for the life of me I can't find the cats you guys have stated!!
well I did get the driver side cat, direct fit bolt on for basically cheap so no cut/weld involved but have a hard time finding the passenger side one haha.
ah well maybe in due time
next project will be brakes and I see carid has a pretty good price on the powerstop package drilled and slotted rotors
I'd go with rockauto but they kill you on shipping
well thanks all for the info!!
probably won't fit but ty tho
wierd that it seems the 2012 is like a ******* child.. not much posted on it it seems like or very limited seems its easier stuff is good and laster but these models don't have much unless its just me haha
oh well thanks alot!
