LED Info Request
Old May 2, 2013 | 09:59 AM
kiddhan625's Avatar
Default LED Info Request
Need help identifying the part # to replace my license plate bulb to match the reverse LEDS on a 2012 XFR. Also if possible the part # for the lights under the side view mirrors to match in the same color. Thanks
Old May 2, 2013 | 11:55 AM
chXFS's Avatar
The search button is your friend.
www.jaguarforums.com/forum/xf.../ultimate-led-q-thread-82098/
Old May 2, 2013 | 03:18 PM
hlgeorge's Avatar
Or try:
LED Threads
Old May 5, 2013 | 11:26 PM
AaronW's Avatar
They are T10...same as overhead inside, footwells, mirror flood lamps, licence plate, inside the trunk, the light by the headlights, glove box.
I have all 15 ready and waiting to put in once I get a chance and the weather turns around. Put the license plate bulbs in they were super easy and look much better. Tried white and red and like the white a lot more.
Old May 6, 2013 | 12:48 PM
chXFS's Avatar
So many places and options on we're to buy. Where did you get yours?
Old May 7, 2013 | 07:04 AM
BigCat09's Avatar
Vleds are the best out there.
Old May 8, 2013 | 05:05 PM
psinsyd's Avatar
Looking to do vleds only in the license plate area.
Which vled model did everyone here go with? I want something with the 5k light range, but want the same brightness as stock so it isn't glaringly obvious that the lights are aftermarket.
I was initially looking at these but they could be too bright.
5K WHITE 10 LED LIGHT BULBS 194 158 168 2825 | 1 PAIR
Old May 8, 2013 | 07:55 PM
hlgeorge's Avatar
I got all of mine from ebay. Most came from China and were good quality. Even found the ones for the interior mirrors. Cree are the brightest.
Old May 8, 2013 | 08:32 PM
Ish's Avatar
Ish
Cant take the credit for this, but there is a 5 LED version of that light that has been recommended for interior use by other forum members.
5K WHITE 3 CHIP 5 LED LIGHT BULBS 194 168 158 2821 | 1 PAIR - 194 - 168 - 158 LED - Bulb #
Old May 10, 2013 | 07:53 PM
psinsyd's Avatar
Just pulled the trigger on these.
I'll keep everyone posted how they work out.
5K WHITE HIGH POWER LICENSE PLATE MAP PARKING LED BULBS 194 168 158 | 1 PAIR
Old May 10, 2013 | 09:31 PM
hlgeorge's Avatar
Without a lens of some kind, LEDs are directional. The ones that have one LED should be mounted directed to a lens. Putting the single LED lamps in place of the incandescent ones that use a reflector from the side do not work very well. The reflector style lamp holders need an LED that shines in multiple directions. This was the case on most of the lamp mountings on my car. I used multiple SMD LED T10 lamps to create a better light radiance.
Old May 11, 2013 | 08:05 PM
psinsyd's Avatar
Crap, thanks. Was wondering about that but didn't want something too bright. I'll see if I can cancel the order and swap it with a different model.
Old May 12, 2013 | 05:50 PM
hlgeorge's Avatar
I have found that when replacing with LEDs, you don't find many that are TOO bright. The only ones I got that were too bright was replacing the footwell lights. I bought SMD board style lights that had 24 LEDs on them. I toned them down by coloring them with a blue permanent marker and they look very good.
philwarner
Jan 31, 2016 09:36 AM
10 XF Premium
Oct 2, 2015 09:22 PM
inactualis
Oct 2, 2015 11:13 AM
LilaJagHubby
Oct 1, 2015 01:47 AM
Rocky15
Sep 28, 2015 04:59 PM
