Problem with Touch Screen (keep restarting, can't get past the Jaguar screen)
Old Aug 8, 2023 | 11:08 PM
wannajag's Avatar
Replacing the battery resolved that.
Old Aug 10, 2023 | 01:50 PM
Long Islander's Avatar
I had a problem with the screen not showing anything (no seat heater/cooling buttons, no way of turning the radio, no Nav, etc). My wife found the solution, which is very simple. Lock the car using the little black button on the outside of the driver door (not other doors, not the remote key fob). After a couple of minutes, when you open door and then start the car, the infotainment screen works fine. Now we leave the Jaguar locked all the time, even when it's in the garage.
Old Aug 11, 2023 | 08:29 AM
wannajag's Avatar
long Islander, do you think your battery is weak? My thought is that the locking of the car is putting the car into a mode where the BMS disconnects the battery from drawdown thus leaving you better equipped to power the system.
I know it sounds goofy, but when the battery goes these cars become basket cases.
Old Aug 12, 2023 | 09:45 AM
Thanks for the input. I have an AGM battery that I bought in September 2016. I don't know if there's way to test a sealed battery like an AGM battery. How do you test a sealed AGM battery? Also, AGM batteries have a very long life.
Old Aug 13, 2023 | 04:18 PM
wannajag's Avatar
My last one lasted six years less a month.
Old Aug 27, 2023 | 11:31 AM
I got a new AGM battery from Walmart (delivered to my home for free) and that solved the issue. It's been over a week now and the touchscreen problem is solved. Thanks! Now I can leave the car unlocked in the garage as before. BTW, the H8/Group 49 AGM Everstart battery has the same specs as the Delco and Motorcraft batteryon the Walmart site of the same size but is cheaper than those two and has a 4 year warranty instead of a 3 year warranty but shows as will not fit the Jaguar XF even though it is the same size. So, it's not shown when you put in Jaguar XF. You have to look for the Everstart AGM H8 battery.
Old Aug 28, 2023 | 09:12 AM
clubairth1's Avatar
Community Influencer
I also have just picked up the Walmart H8 battery for my XJ. It even says made in Germany on mine.
Another great suggestion from this forum too!
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
convincor
Sep 3, 2015 08:03 PM
Terrance Williams
Aug 26, 2015 11:50 AM
