Subtle clunk noise as XF hits 16 kmh
Old Aug 26, 2018 | 12:24 PM
rfhusband's Avatar
Default Subtle clunk noise as XF hits 16 kmh
Does anyone know the source of an audible clunk noise which occurs the first time the car exceeds 16 kmh / 10 mph after starting the engine?
Thanks,
Bob
2011 XF, V8, Luxury Premium Edition, 70,000 km
Old Aug 26, 2018 | 01:10 PM
John Williams's Avatar
That will be the doors locking!
Old Aug 26, 2018 | 01:44 PM
rfhusband's Avatar
I guess that could have been a possibility for some, however my doors are set to lock at 32 kmh. Made me smile, though. Reminds me of being a computer technician and having to start the support call with the question, "Is your computer plugged into the power?" :-)
This is a much quieter sound which seems to come from the engine or transmission areas.
Old Aug 26, 2018 | 01:54 PM
elviukai's Avatar
i have the same noise at same speed(around 20km/h maybe) nd i think its torque converter lock up
Old Aug 26, 2018 | 01:58 PM
rfhusband's Avatar
Funny it is only once every trip, not each time the car accelerates to this speed. I noticed the parking assist screen shuts off at the same time (after backing out of a space) and wondered if there was some sort of mechanical interlock that was letting go. Have you had yours checked out by a mechanic (or are you not concerned)?
Old Aug 26, 2018 | 02:04 PM
elviukai's Avatar
yes only once after car start drive. and sometimes its less noticeable if car warm up. I;m pretty sure its torque converter and or gearbox. I have changed both converter and gearbox and car does the same. which engine do you have 4.2SC or 5 NA?
Old Aug 26, 2018 | 05:20 PM
rfhusband's Avatar
Okay, good to know someone else has heard it. I'll not make a special trip to the mechanic for it but will mention it at the fall servicing before I put the car away for the winter.
Mine is V8 5.0 litre, without supercharger.
Thanks,
Bob
Old Aug 26, 2018 | 08:07 PM
BritCars's Avatar
It's the ABS system. It does a self check of the system around 5 or 10mph (I forget which) the first time you pull away.
Perfectly normal. And in fact reassuring that it works!
Old Aug 28, 2018 | 04:54 PM
rfhusband's Avatar
Hi BritCars, Your post makes sense to me. Thanks for weighing in.
Regards,
Bob
P.S. Question closed for me!
Lawrence
XJ40 ( XJ81 )
Feb 2, 2015 09:36 PM
Lawrence
Oct 4, 2014 02:21 PM
Vinnyboy
24
Sep 6, 2013 03:03 AM
JWT
Jul 6, 2010 03:57 AM
Frankie
XJ40 ( XJ81 )
Apr 13, 2009 01:31 PM
