swap 3.0 with 5.0 in 2013 AWD
Old May 2, 2019 | 05:39 PM
bfarrell's Avatar
Default swap 3.0 with 5.0 in 2013 AWD
Blown 3.0 engine in a 2013 xf 3.0 awd.
my question is will a 5.0 fit into this AWD co figuration ?
i figure since i’m screwed on warranty i might as well make it interesting by swapping in something unique like a 5.0 as it fits into the f type AWD.....any ideas?
thanks.
b
Old May 2, 2019 | 06:21 PM
Adam J's Avatar
i believe the 3.0 block to be same overall dimension as 5.0 block. they just forego drilling the rear most 2 holes.. that's the ''good news''
reality is you likely have to spend more than the vlaue of the car to do so and make it work.. maybe a ls swap cheaper and more hp potential? heresy?
Old May 3, 2019 | 07:46 AM
pab's Avatar
pab
Plus there is no AWD version of the 5.0 (and there must be some reason for that) so try'n to create one is guaranteed to be trouble.
Best to shop for a replacement 3.0, but as said above, even that will be more $ than the car is worth.
Jaguars, cheap to buy used, expensive to maintain, impossible to sell...
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
Old May 3, 2019 | 03:18 PM
2013XF3.0's Avatar
My engine blew up a few months back as well, same year, same model. What happened to yours? I ended up swapping it with a 3.0 from a 2015 XJ.
Old May 3, 2019 | 04:44 PM
bfarrell's Avatar
yes as i thought. Just lost confidence in the 6 it my first non v8
i hate the sound of the 6 but needed the awd. it’s a winter car however it should not have puked at 70,00km
Old May 3, 2019 | 05:24 PM
KEEP IT CIVIL
Members following this thread will notice it has become a lot shorter. I've cleared out the posts trading insults. If I need to come back to the thread, I'll move to the next level.
Old May 3, 2019 | 08:22 PM
bfarrell's Avatar
Originally Posted by GGG
KEEP IT CIVIL
thank you
barry
Old May 3, 2019 | 08:27 PM
bfarrell's Avatar
dealer has a 3.0 long block for 18k plus a 5 k rebate for a core
i have no choice as the car is mint everywhere else and not worth scraping..... i just though a 5.0 AWD would be a nice ride....i’ll have to settle for the 6
nice idea on a LS engine as the tranny will fit with an adaptor.
still it’s a ton of work.....never hurts to look into options
b
Old May 3, 2019 | 08:28 PM
bfarrell's Avatar
great idea but not cheap...
Old May 4, 2019 | 10:12 PM
AJ16er's Avatar
b
There is somebody here who had his 4.0L V8 rebuilt for five grand at an independent Jaguar shop. Maybe get another estimate from such a place.
Old May 5, 2019 | 01:25 PM
bfarrell's Avatar
Default still looking for options
looks like a 3.0 long block costs the same as a 5.0 so back to my original idea of putting in a 5.0 then it’s AWD (like the f type) ..question...what else would i need to make this work ie) electrics, ecu, cooling etc...any helpful input would be welcome...
Old May 5, 2019 | 04:30 PM
bfarrell's Avatar
lower end...either a rod or crank bearing.... this is happened with more frequency than i’m comfortable with.... beware
Old May 5, 2019 | 05:21 PM
bfarrell's Avatar
Default awd 5.0....
there’s a 5.0 AWD ftype.... although i’m not sure it’s the same AWD however, it may be the same
Old May 6, 2019 | 10:00 AM
clubairth1's Avatar
Community Influencer
You will be better off getting another car. What would a 2013 AWD XF cost you?
The lower end is in the $18K range.
Any idea why the motor went out?
Low oil?
Old May 6, 2019 | 11:02 AM
lotusespritse's Avatar
Low oil?
Often hard to get the whole truth. Ask any mechanic for their stories of customers saying, "I dunno, it just broke down all by itself," and then the mechanic finding out on their own that the owner forgot some very important details!
Old Nov 13, 2023 | 09:45 AM
JoshMcMadMac's Avatar
I know this is an older thread, but has anyone successfully pulled off a 5.0SC AWD XJ? My 3.0 just went belly up and long blocks seem to be very similarly priced.
Old Nov 14, 2023 | 03:11 AM
JagV8's Avatar
It's a HUGE task. Cheaper to buy another car.
Old Nov 14, 2023 | 07:31 AM
clubairth1's Avatar
The answer as JagV8 posted is no.
Old Nov 14, 2023 | 09:48 AM
What is huge about it though? Beyond physically swapping the engine, what else changes beyond coding?
Old Nov 14, 2023 | 02:15 PM
clubairth1's Avatar
Everything.
