Trunk won’t open
Old Oct 26, 2022 | 08:58 AM
JaguarXF-2012's Avatar
Default Trunk won’t open
Trunk won’t open, any ideas of which module I need? Jaguar told me the module needs replacement. They also told me the module itself would cost €1000. Any tips on which module I have to buy and how to replace it? I think it must be the rear body control module but I’m not sure which number I need.
Thanks already!
Old Oct 26, 2022 | 10:41 AM
John Williams's Avatar
Can you open it with the emergency key??
Could be the boot/trunk loom near the hinge, the wires snap, but can be easily repaired.
Old Oct 26, 2022 | 10:59 AM
Thanks already!
Welcome to the forums JaguarXF-2012,
Did Jaguar do this diagnosis with the benefit of a diagnostics session or guesswork? I agree with John a harness break is a possible cause as is a faulty lid latch which is under €150.
Enjoy the forums.
Old Oct 26, 2022 | 12:35 PM
Enjoy the forums.
I think it was just a “guess”. The trunk does still open with the emergency key but not with the remote, de button inside or the button on the trunk itself.
Do the wires inside the trunk break more often?
BTW, thanks already for your help!!
Old Oct 26, 2022 | 01:28 PM
It's a simple thing to peel back the rubber boot at the hinge point to inspect the wires.
Old Oct 26, 2022 | 05:42 PM
BritCars's Avatar
Yes. The wires bend every time you open it and break over time. Mine did about 5 years and I had to replace the trunk loom. It wasn't expensive - maybe $150 and an easy fix. DIY.
Old Mar 8, 2023 | 06:28 AM
Mark R's Avatar
Hi,
Was this ever resolved? I also have 2012 XF the facelift with trunk soft close. Latch will only open manually with key. I took a chance and got a new latch but no joy. Checked the harness between boot-lid and car for any wire breaks and continuity was all good. Does anyone know where the relay is for opening the boot on this model?
Old Mar 8, 2023 | 12:31 PM
Originally Posted by Mark R
Hi,
Hey, I tried all things that could be the trouble makers except the module itself because of the expensive repair costs. So with my XF 99% the module was the problem. It’s the module on the right side of your trunk behind the fabric.
Good luck tho!
schuess100
Oct 19, 2022 04:37 AM
Roc3207
Sep 11, 2017 05:17 PM
muskox3437
Dec 10, 2016 11:56 AM
arthurdaley
Jan 3, 2013 11:04 AM
Teegig
May 26, 2011 10:04 PM
