Water pump/crossover pipe replacement
Old Aug 12, 2018 | 11:48 AM
Roman Markiewicz's Avatar
Default Water pump/crossover pipe replacement
Hey guys. Need a little guidance. Got a 2013 XFR with 34k miles on her. Replacing the water pump and the crossover pipe as I noticed slight moisture around the WP.
Any other suggestions on what to check/replace/clean? Maybe replace injectors, any specific fluids/coolants??
Old Aug 12, 2018 | 05:59 PM
lotusespritse's Avatar
Clean gunk off intake valves and replace all of the rest of the plastic pipes in the cooling system (there are many).
Old Aug 16, 2018 | 12:48 AM
Bigg Will's Avatar
When I did mine. https://www.jaguarforums.com/forum/x...change-189069/
Bigg Will
Apr 17, 2021 08:37 PM
gmacaz
Feb 11, 2016 02:58 PM
tubeviper
Dec 28, 2014 04:01 PM
snoack321
Mar 21, 2011 01:51 AM
