What's tis cable in the AUX port?
Old Jan 24, 2020 | 06:26 AM
prolepsis's Avatar
Default What's this cable in the AUX port?
Hello there,
This week I purchased a 2011 XF 5.0 Premium with less than 60,000 km on it. I'm still exploring it and wishing I had spent more time inspecting it prior to purchase ... but it's too late now! I noticed a cable plugged in to the AUX port which I'm pretty sure is not original spec (see pic). Any ideas what it might be and how to find out? BTW, I'm located in South Korea and asked on a forum here and the response was about Bluetooth, but I'm not sure that's correct.
Old Jan 24, 2020 | 08:46 AM
User 42324's Avatar
Go to the Audio settings on your dash display, select Aux & see what happens & what it says.
Old Jan 24, 2020 | 08:54 AM
litteredwithfaults's Avatar
Find the other end, definitely not stock so nobody here would know for sure what the previous owner was getting up to. You can just unplug it and the aux option should work for any of your own devices.
Old Jan 24, 2020 | 05:52 PM
prolepsis's Avatar
Of course I did this before posting.
Old Jan 24, 2020 | 05:54 PM
prolepsis's Avatar
Yep. Already tested that the port works. I posted in the hope that I wouldn’t have to start disassembling things.
Old Jan 24, 2020 | 06:51 PM
davetibbs's Avatar
Do a scan for bluetooth devices other than the car. I bet it's an external bluetooth receiver plugged into the AUX port.
Old Jan 24, 2020 | 08:02 PM
TXFireblade's Avatar
Hi Dave,
I've been trying to contact you by PM but can't tell if you've seen them. Can you let me know either way?
Much appreciated.
Old Jan 24, 2020 | 09:09 PM
BritCars's Avatar
If it's the silver one at the top of the picture, isn't that the old Apple connector? If so, you can connect a Bluetooth receiver like the Tube2Air and stream music over BT to the car. (The 2011 allows you to BT connect to a phone for calls but doesn't have streaming BT audio built in so you need a small receiver device)
Old Jan 25, 2020 | 03:50 AM
prolepsis's Avatar
That’s a bet I’ll happily take up. What’s your wager?
Old Jan 25, 2020 | 04:00 AM
prolepsis's Avatar
After playing around in the car today, I now suspect the cable might be from the 3rd party nav systems that were fitted in this market. The systems have digital audio and DMB video functions but I haven’t got them working yet to test my theory. The nav audio seems to play from a dedicated speaker somewhere on the driver side dash. The nav audio doesn’t play through the audio system but I expect the DMB video would. It’s important to have quality movie sound while you’re driving!
Old Jan 25, 2020 | 07:31 PM
Jssaab's Avatar
This is correct.
I also bet the aux is connected to an BT reciever somewhere (shich will allow only streaming music to the AUX)
It looks like yhou have the iPod cable there (silver connectgor in the picture.)
You need a "tune to air connector ( like mentioned above) to stream music and control through the touchscreen. Works well, I had one in my 2011 XFR. Here is a set so you can see how it works.
Jaguar bluetooth streaming Jaguar bluetooth streaming
Since it seems like you already have the cable have one you only need this
Bluetooth 30 pin adapter Bluetooth 30 pin adapter
Old Jan 27, 2020 | 06:03 AM
prolepsis's Avatar
Sure, I'll take that bet.
Michaell
Jul 6, 2017 10:27 AM
Lafe
Jun 19, 2017 10:04 PM
ivicks
Jun 2, 2017 05:25 PM
Elkulichi916
May 13, 2017 06:52 PM
vacolorito
Aug 22, 2016 12:02 PM
