will XJ or XK Wheels fit my 2013 XF?
Old Nov 25, 2013 | 08:06 PM
748667's Avatar
Default will XJ or XK Wheels fit my 2013 XF?
I have read and have seen mixed answers to this question. Even one where I saw pictures of XK wheels on a XF, Can anyone tell me for sure? I have found some XJ Venom wheels, would love to see on my XF... Please help Thanks
Old Nov 25, 2013 | 09:00 PM
chXFS's Avatar
Yes, XJ and XK wheels will be fine. You will only run into trouble Pre 2010 for the XK rear wheel only. It has a very low offset.
Old Nov 25, 2013 | 09:51 PM
748667's Avatar
Thanks so much...
Old Nov 25, 2013 | 11:56 PM
caviarjag's Avatar
I currently run XJ wheels on my XF. 245 fronts with 275 rears (stock XJ sizes). The offsets push the wheels out ever so slightly and make a huge appearance improvement over stock XF wheels.
Old Nov 26, 2013 | 05:48 AM
748667's Avatar
I am looking at some that are 275/35/20" on a 10" wheel width on the rear wheels. Is this what you have? Do you have any pictures?
Old Nov 26, 2013 | 09:52 AM
748667's Avatar
Old Dec 2, 2014 | 03:38 PM
748667's Avatar
Default XJ Venom wheels on 2013 XF
They fit fine... I have 245/35/20 on front 9" Venom and 275/35/20 10" venom on rear...
Old Dec 3, 2014 | 08:37 AM
pab's Avatar
pab
Recommend you check the following link to make sure:
http://www.discountedwheelwarehouse.com/Jaguar___Vehicle_Bolt_Pattern_Reference.cfm
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Dec 4, 2014 | 08:58 AM
pab's Avatar
pab
Hey, just wondering, did they change the size of the wheel well in the trunk on XFs v.s., S-Types (our cars are highly related...)? Does a regular wheel/tire on an XF fit in the well?
The OEM wheel tire (245/40-18) on my '08 S-Type 4.2 fits in the well. However, a wheel/tire from the set of XF wheels I put on my car last summer (245/45-18) does not fit. I figure the S-Type wheel well was sized when the car was designed in the late 90s when typical wheels were around 16 inches. But as the size of wheels grew the wheel well ended up being maxed out at 18".
How does that compare to XFs? Can you fit an 18" in the well, what about 19s?
Jaguar - it's not an automobile, it's a Motorcar
aholbro1
Dec 29, 2024 06:46 PM
smith356
Oct 7, 2015 06:41 PM
Armor6
Sep 14, 2015 07:56 PM
metalmarty
Sep 11, 2015 07:05 AM
jfitzoz
Sep 7, 2015 04:28 AM
