XF 2010 engine running hot warning light
Old Jul 10, 2018 | 10:57 AM
tarra72's Avatar
Angry XF 2010 engine running hot warning light
recently my engine running warm light comes on. radiator fans runs and looks only a little low on coolant. also no signs on leaks on drive way or smell of antifreeze
any suggestions on issues
Old Jul 10, 2018 | 11:21 AM
JagV8's Avatar
Wait for a mod to move to correct forum.
And then put in more car details!!
Meantime... do NOT let it overheat or you may need a new engine. By the time the gauge says it's too hot it can already be too late
Old Jul 10, 2018 | 12:51 PM
Originally Posted by tarra72
recently my engine running warm light comes on. .....
Welcome to the forum tarra72,
I've moved your question from General Tech Help to X250 forum. This is the place to post questions about your model.
Old Jul 10, 2018 | 02:44 PM
Supercharged81's Avatar
Default Overheating
the biggest weakness in these cars that causes over heating is water pump failure, also the plastic lines break. I have the 2010 XF Supercharged, just about every XF from that era will need a water pump replacement at some point. Also as previously posted try to avoid driving the vehicle until issue is dealt with. Since the vehicle has no real temp gauge over heating can occur quickly, damaging the engine.
Old Jul 10, 2018 | 11:01 PM
lotusespritse's Avatar
Yes, the XF's and many other cars have weak points of plastic piping that cracks open and water pumps that start to leak after over 50K miles, but when you get right down to it, the XF does not have an exotic engine cooling system and troubleshooting it for those and any other problems is the same as any other car. So with that said, start watching videos if you want to know how to troubleshoot overheating instead of having everyone reinvent the wheel on here:
Old Jul 11, 2018 | 09:09 AM
No attempt at reinventing the wheel here. Just friendly advice. The XF'S from that era are sensitive to over heating, and it can damage the engine very quicky. I wouldn't want that to happen to anyone. I also find it interesting someone would post a Scotty Kilmer video on a Jaguar forum, since he bashes European vehicles, and their owners so heavily.
Old Jul 12, 2018 | 04:37 AM
Bigg Will's Avatar
My bet is a bad Thermostat if it's the original, and you have no leaks.
Old Jul 18, 2018 | 04:36 PM
leadfoot4's Avatar
I'm not trying to hijack the thread, but just trying to get some more information. First, let me say that I'm big on preventive maintenance, and don't have any problem with replacing parts that MAY be either questionable, or at the end of their useful life. Having said that, we have a 2009 XF, with the 4.2 liter engine. I've heard stories about questionable plastic components, both the thermostat housing/water crossover, as well as plastic water pump impellers. My question is, even though the mileage is low on this car (36,000 miles), it's still 9 years old, and these components have gone through 9 years of both summer heat as well as frigid winters. Therefore, should I consider replacing these components before they fail?
If the answer is yes, how difficult is it to swap out the water crossover piping? Pictures show 4 bolts holding it in place, but when I look at our car, I don't see where these 4 bolts are. They seem to be pretty well buried under either the crossover itself or other components. I'd hate to start disassembling things, only to find out that I can't actually do this at home, and/or I need special tools, in order to do this....tools that only the dealer has.
Any advice would be appreciated!
JaguarVDP
Dec 1, 2018 09:33 AM
j2times
May 16, 2017 02:27 PM
charlie.p
Oct 5, 2016 09:12 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
