XF 250 engine shakes violently at idle
Old Nov 21, 2019 | 07:35 PM
PJ704's Avatar
Default XF 250 engine shakes violently at idle
I just got my spark plugs changed since I am just over 100k miles. Prior to that, I notice a violent shake once in a while when I am idle, parked in my garage. I thought it might be the spark plugs so got that changed 2 days ago.
i just now felt the violent shake again while idling in my garage. This one is hard to Troubleshoot since it doesn’t always happen.
can someone help me troubleshoot this? Any idea what it can be?
Old Nov 21, 2019 | 08:01 PM
lotusespritse's Avatar
A spark plug problem wouldn't be intermittent, so it was time to change them, but wasn't the problem.
The best next step is to get a diagnostic scanner (with the Jaguar XF software) attached to the car to check for codes. It sounds like a cylinder is shutting down and causing the shake at idle.
Old Nov 21, 2019 | 08:35 PM
PJ704's Avatar
any scanner tool you recommend?
Old Nov 22, 2019 | 10:56 AM
JagV8's Avatar
It may be an air leak (*) so watch the fuel trims before, during and after the shake
(*) or indeed any of several other things e.g. bad connector interrupting a sensor value, failing O2 sensor, part-blocked exhaust,
Old Nov 22, 2019 | 11:55 AM
PJ704's Avatar
Air leak? Could this be related to the center air intake tube under my hood that is split open? I am using tape to hold it together right now, hoping air won't escape or go in.
Old Nov 22, 2019 | 04:28 PM
JagV8's Avatar
Ouch! Yes. Fix it urgently.
Old Nov 22, 2019 | 05:12 PM
OzXFR's Avatar
Agreed.
Additional unmetered air is coming in after the MAF sensors and not being monitored, odds on to be the cause of your rough idle.
The car will run with the MAF sensors unplugged or removed (been there done that) but it will idle very rough.
Old Nov 22, 2019 | 08:45 PM
PJ704's Avatar
Originally Posted by OzXFR
Agreed.
been driving it a few months like this now. Is there any long term issues?
Old Nov 23, 2019 | 02:17 AM
JagV8's Avatar
Engine damage / cat damage / damage to engine mounts / bad mpg / bad emissions, at least.
Old Nov 23, 2019 | 08:48 PM
PJ704's Avatar
any place I can buy the air intake tube for a good price?
Old Nov 23, 2019 | 08:53 PM
OzXFR's Avatar
What year, what sub-model, what engine?
I'm guessing 5.0 V8 NA but who knows!
Old Nov 23, 2019 | 10:25 PM
PJ704's Avatar
hi ozxfr,
2010 xf premium v8 5.0L. NA
Old Nov 24, 2019 | 10:10 AM
JagV8's Avatar
I'd try scrap (breakers) yards.
Old Nov 24, 2019 | 12:01 PM
PJ704's Avatar
Where do I find those?
Old Nov 24, 2019 | 03:27 PM
JagV8's Avatar
I'd use a search engine.
Old Nov 25, 2019 | 03:22 PM
Jssaab's Avatar
car-part.com
Air box for Jaguar
Old Nov 27, 2019 | 01:56 PM
PJ704's Avatar
Originally Posted by Jssaab
car-part.com
Air box for Jaguar
hm...That doesn't look like it will fit my car though but I'll look. Thanks all.
Are the parts here reliable?
Old Nov 27, 2019 | 06:50 PM
Jssaab's Avatar
They sell used parts from wrecked cars i don't know any of them just use the search
Jag-o-nomic
Feb 15, 2017 04:06 AM
harvest14
Aug 20, 2016 04:28 PM
zathras
Oct 12, 2013 10:19 PM
harryf
Dec 29, 2012 10:42 AM
daxter1987
Sights N Sounds
Oct 3, 2012 09:50 PM
