XFR vs XFR-S Dampers/Struts
Old Aug 26, 2020 | 03:26 PM
Jaaaggg's Avatar
Default XFR vs XFR-S Dampers/Struts
I just ordered the Spires sport lowering springs for my XFR and in talking to Matt from Spires, he mentioned the spring rates are based off of the OEM XFR-S springs, but will provide ~20mm drop on the XFR. I am replacing the rubber boots the springs will sit on all four corners.
This got me thinking about replacing the dampers with the ones from XFR-S, but looking at the online Jaguar parts list, the same part number is listed for both the XFR/XFR-S dampers/struts. I was under the impression they used different dampers because the XKR and XKR-S actually have different part numbers for the dampers and I believe even the color of the dampers is green on the XKR and yellow on the XKR-S.
So the XFR-S uses the same dampers as the XFR with different CATS tuning?
Old Aug 27, 2020 | 03:43 PM
Jaaaggg's Avatar
No one knows?
Old Nov 26, 2021 | 02:16 PM
Reaxions's Avatar
Although I could be wrong, upon initial research, it looks like the dampers might be the same, just with the adaptive settings reprogrammed (firmer in both their baseline and Dynamic settings on the XFR-S).
However, while the dampers might be the same, the coil springs appear to be different, with the XFR using part# C2Z11479 vs XFR-S using part #C2Z25905. According to the press releases, the XFR-S springs appear to be stiffened 30-40 percent compared with the XFR. I don’t know if the XFR-S springs are also shorter, but I’d assume they might be a tad shorter, too, along the lines of standard XF springs being ~5mm taller than the XFR springs which are ~5mm taller than the XFR-S springs.
Can anyone confirm or refute for clarification? Thanks.
Old Nov 28, 2021 | 09:04 AM
MoJo88's Avatar
Different dampers and different springs.
Old Nov 29, 2021 | 10:36 PM
Reaxions's Avatar
Any chance you have the part numbers for the XFR-S dampers? I'm about to pull the trigger on the "XFR-specific" springs from Spires, so am curious about a few things.
Old Nov 30, 2021 | 01:46 AM
MoJo88's Avatar
Dampers:
Front - C2Z25908 - DX2M-18045-AA
Rear -
C2Z25909 - DX2M-18080-AA
Springs:
Front - C2Z25904 - DX2M-5310-AA
Rear -
C2Z25905 - DX2M-5560-AA
Old Nov 30, 2021 | 09:08 PM
Jaaaggg's Avatar
XFR dampers are green in color, whereas XFR-S are yellows
Old Dec 1, 2021 | 11:50 AM
MoJo88's Avatar
@Jaaaggg
Cant believe nobody replied to your question. Good to see you got the answer in the end.
Old Dec 1, 2021 | 01:49 PM
Jaaaggg's Avatar
Originally Posted by MoJo88
@Jaaaggg
Appreciate your response! I ended up just buying an XFR-S instead of changing the dampers on the XFR
thefisherman
XF (X260)
Jul 18, 2020 01:42 PM
H.Jones
Oct 25, 2015 07:24 PM
bklynchris
Jun 10, 2012 06:36 PM
davidcalgary
Jun 22, 2011 08:45 AM
