2000 xj8 upper oil pan... (rod bearings)
Old Aug 22, 2011 | 04:15 AM
jays78zride's Avatar
Default 2000 xj8 upper oil pan... (rod bearings)
hey im trying to do rod bearings in my 2000 xj8 and i have to drop the upper oil pan, i was wondering if anyone could help me so i know what i have to pull.
thanks, jay
Old Aug 22, 2011 | 04:52 AM
Sean B's Avatar
The engine. I've not seen this work carried out, without the engine removed.
Old Aug 22, 2011 | 05:13 AM
avos's Avatar
You need to drop the full suspension frame (and make sure you fix your engine, so it doesn't drop with it), then you can take out the lower bed plate (oil pan isn’t enough), and you will get access to the rods. I thought this was described in the JTIS, but can’t remember and can’t check now.
Old Aug 22, 2011 | 08:23 AM
motorcarman's Avatar
I guess the cam chains and gearbox will hold the crank from falling out?????
bob gauff
Old Aug 22, 2011 | 08:43 AM
avos's Avatar
bob gauff
No no, there is no need to use the chains to hold the engine, that would only mean more work, just use the fead belt
Jaguar has actually a special tool to hold the engine, something like this (but then a tad smaller):
Old Aug 22, 2011 | 10:12 AM
Sean B's Avatar
yep I stand corrected, Avos is 100% just seen the process on the JTIS disc, it means letting the upper shock bolts go, then the subframe, you're only looking to get a spanner in to release the bedplate.
You can buy dummy crank journals from SPX. I think around £60 for the set.
Old Aug 22, 2011 | 10:56 AM
plums's Avatar
You can rent the support tool. Someone in a past post used a engine support tool that is commonly rented out for FWD vehicles when the front suspension is dropped out to work on the transaxle. The tool is supported in the fender lips running along the two sides of the hood.
Old Aug 22, 2011 | 04:48 PM
thanks you guys! ive only had this thing for a week i just put a fuel pump in it and knew it had a knock... its only got 74k miles on it and i got it for 1300$ and got 100 into a fuel pump so far... im thinkin ill have a pretty sweet car for under 2000$ when its done, i just wish alldata had info on jags! i just found out what jtis is so im downloading that right now haha
Old Aug 22, 2011 | 08:31 PM
jimlombardi's Avatar
Default Connecting Rod Bearings R&I PDF from JTIS21
Hi jays78zride
As a new forum member, you will probably not be to able to view these PDF files.
New forum members cannot view them until they at least 10 posts on the forum.
Try not logging as a forum member and you might be able to be on the forum as a guest.
Guests can view attachments.
The forum software also can recognise forum members by using cookies.
Also try using another internet brower other than your default brower (example Firefox instead on Internet Explorer) and do not login, then you should be on the forum as a guest. Or if you have another PC you access the forum and not login.
I created a few PDF files from the JTIS21 software that covers the Connecting Rod Bearings Removal and Install along with a list of what other parts and other assemblies that might need to be removed.
Here are the main 4 PDF files:
XJ 98-03 Connecting Rod Bearings R&I.pdf
XJ 98-03 Engine Front Cover R&I.pdf
XJ 98-03 Upper Oil Pan 4.0L R&I.pdf
XJ 2000 Front Crossmember R&I.pdf
I am not sure all these procedures need to done. Sure looks like a major project.
Mentions: twin fan and motor assembly, timing cover, front crossmember, Front Accessory Drive, Idler Pulley, crankshaft damper, intake tube from throttle body, intake tube / air flow meter / air cleaner cover assembly, purge valve, on-plug ignition coils, both camshaft covers, variable valve timing solenoid.
Also: oil pressure switch, crankshaft position sensor, air conditioning compressor, exhaust downpipe to oil body pan, oil pickup pipe, lower steering column, both front road springs, Remove lower nut and bolt from front shock absorber, remove steering rack.
And this is not the complete list.
The hands-on experts probably have a way to shortcut many of the items listed in these PDF files.
Jim Lombardi
Old Aug 23, 2011 | 12:31 AM
sparkenzap's Avatar
BTW- Alldats does have this jag's info-
Old Aug 23, 2011 | 06:53 AM
Hi
Alldata has the connecting rod bearings service time as 14.7 shop hours.
It also shows the part number for our 2001 XJ8 as NCC1612BA2.
The JEPC (Jaguar Electronic Parts Catalog) lists the following:
NCC1612BA2 (color blue) NCC1612BA3 (green), NCC1612BA4 (yellow)
From VIN (F41863)
AJ83902 (blue), AJ83903 (green), AJ83904 (yellow)
These part numbers are for the half shell, so 2 of them are required per connecting rod. You will need 16 half shell parts to replace all the connecting rod bearings.
Gaudin Jaguar Parts prices for the NCC1612B parts numbers $22.20 $16.65 and $21.65 $17.59 for AJ8390 parts numbers.
I will post the other procedures that are not in the my earlier post when I am able to find all of them.
Jim Lombardi
Old Aug 23, 2011 | 08:50 PM
Thumbs up
thank you guys! i tryed downloading jtis but it got messed up and wouldnt extract right, but now it looks like i have all the info i need! alldata has some info but not nearly enough to get me by. i know i can manage dropping the upper pan without this info but i would rather not take anything apart that i dont have to. thanks again guys!
Old Aug 25, 2011 | 08:52 AM
Hi
Try downloading JTIS21. Go to post#1 in the JTIS21 Thread:
https://www.jaguarforums.com/forum/x...uctions-54640/
Jim Lombardi
aholbro1
Dec 29, 2024 06:46 PM
Bcrary3
Sep 12, 2021 05:41 AM
corysansburn
Sep 10, 2015 06:15 AM
obwoodie
Sep 3, 2015 07:45 PM
Harry Dredge
Sep 3, 2015 03:04 AM
