high pinched whining noise from engine,
Old Jan 20, 2014 | 07:20 PM
vincent661983's Avatar
Default high pinched whining noise from engine,
not loud but sharp noise from the engine, any ideas please
Old Jan 20, 2014 | 08:03 PM
Badbenz94's Avatar
Check your water pump? I believe now that's where mine was coming from.
Chris
Old Jan 20, 2014 | 09:07 PM
i will eliminate about water pump just changed a new one last summer,but thanks
Old Jan 21, 2014 | 06:19 AM
xjay8's Avatar
Is this noise continous or a 'cheep, cheep, cheep, sort of sound?
If the latter you may want to change the serpentine belt.
Old Jan 21, 2014 | 07:01 AM
Sean B's Avatar
pulley bearings, s/c belt or aux belt, compressor bearing, alternator bearing, power steering pump etc etc.....where does it sound like it's coming from, does it go away when the car is warmed up?
Old Jan 21, 2014 | 09:14 AM
yes, noise is continuous
serpentine belt was also changed 2 years ago,I doubted if it failed prematurely. I will looking around some other areas.
to Sean. yes, this winter has been harsh and it might related to cold engine start.
a separate thread I just opened, I talked about the battery drain. thanks
Old Jan 21, 2014 | 02:01 PM
avt007's Avatar
I would pull the SC belt and see what happens, then pull the other belt and see how it sounds. Obviously you can't run it for more than 30 seconds or so like that but it may narrow down the source of the noise.
Then while the belt is off, spin each pulley by hand, feeling for drag, rough bearings, and noise.
Old Jan 28, 2014 | 03:01 PM
ok, in case you need to know, the answer was that the power steering pump failed ,lost power steering fluid, refilled and turned foamy. and ended up with replacement.
PMKimpton
Aug 3, 2019 08:22 PM
user 652867429824
Sep 5, 2015 12:53 PM
obwoodie
Sep 3, 2015 07:45 PM
rachelstr
Sep 3, 2015 12:59 PM
innzane
Sep 2, 2015 10:08 AM
