XJ ( X351 ) 2009 - 2019
12 XJ valet default?
Old Jun 13, 2015 | 10:56 PM
12jagmark's Avatar
Default 12 XJ valet default?
Does anyone know what the default code is for the valet mode for the 2012 XJ?
I reset mine to the factory default with the BD V130 tool, but can't find what that default is in my manual or anywhere.
If this BD V130 SDD tool Would let me set it to what we want that would be good, but it only goes to default.
On the bright side, it did let me program a brand new key, and erase the other keys that didn't come with the car when we bought it.
Old Jun 14, 2015 | 08:58 AM
RoonieQ's Avatar
That's interesting. Is there such a thing as a default code?
On my car valet mode functions by asking me to input a code when I choose valet mode and then I use that same code to later cancel the valet mode. So in this case, unless I forget what code I initially set, there is no default code.
Old Jun 15, 2015 | 06:07 AM
12jagmark's Avatar
Originally Posted by RoonieQ
..., there is no default code.
So it's a new code each time we set it?
I didn't consider that. That would explain why I can't find anything about it.
I could only find direction to have the dealer reset, which I did with my SDD.
I'll give that a try.
Thank you for the explanation!
Old Jun 15, 2015 | 05:52 PM
RoonieQ's Avatar
YW. And yes, that's it exactly. You choose a code each time you use it.
Old Jun 16, 2015 | 09:24 PM
KingFala's Avatar
Default Chinese???
Why is this stuff so difficult? Are the instructions first written in Chinese and then translated into English -- British, American, Australian or Brooklyn; what's the difference!
Old Jun 17, 2015 | 05:14 PM
12jagmark's Avatar
I apologize for taking too much of your time, king.
I'm not quite as sharp as many of you, who get it right the first time on understanding everything.
When I bought the car, the dealer mentioned that they needed to reset the valet code. From previous experience with passwords and codes in general, I was expecting that there was a factory default, including some car security systems I've had.
I appreciate your helpful input for a stupid question. Unfortunately it wasn't my first, and I'm afraid I can't claim that it'll be my last.
But I'll try.
Again, thanks for your help king, and I humbly apologize for the time you spent responding.
Old Jun 18, 2015 | 01:37 PM
KingFala's Avatar
Default Rhetorical Question
But I'll try.
It was meant to be a "rhetorical question", and in no sense demeaning to the question. That's why I don't make money as a stand-up comedian -- generally I'm not funny.
My point, badly made, was why are the directions or instructions often obtuse? Back in ancient times, when I was in charge of some mundane matters, we would write procedures and then test them out with some of the actual users to assure that they would accurately and easily help in understanding the objective.
Sorry if I sounded like a bore.
King Fala (Lou)
Old Jun 18, 2015 | 05:53 PM
Stuart S's Avatar
KingFala,
The difference between English in America and everywhere else is that here in America we drive on the parkway and park on the driveway.
If we can't beat them, we'll confuse the hell out of them until they surrender.
Stuart
Old Jun 18, 2015 | 08:53 PM
johndahlheimer's Avatar
From: Mooresville, NC (Race City USA), home of most NASCAR teams.
Originally Posted by Stuart S
KingFala,
Stuart
That's called psychological warfare. No need to have a defense budget eight times larger than the Russians, to have over 2.5 times their manpower, 4 times their aircraft, nor to have ten aircraft carriers, more than the rest of the world put together, the important thing is to confuse the hell out of them.
Old Feb 23, 2019 | 01:41 PM
Piotr Bajura's Avatar
Hello, which program will reset the valet mide pin?
Old Feb 23, 2019 | 01:50 PM
JLR SSD ?
Old Feb 25, 2019 | 08:39 AM
clubairth1's Avatar
Community Influencer
Are you sure you need to reset it?
Reading above it looks like it's one time use code only and then you enter a different code each time you use it.
Maybe your car is locked in Valet mode now?
Old Feb 25, 2019 | 12:50 PM
bajura's Avatar
The car asked me about the pin. I entered twice 1234. Valet mode was turned on. Now when I want to unblock I enter 1234. I am giving an invalid pin message. I got to the boot through the rear speakers, disconnected the battery for the whole night and nothing. Valet Mode is active.
Old Feb 25, 2019 | 09:27 PM
Stuart S's Avatar
Originally Posted by bajura
... I got to the boot through the rear speakers, disconnected the battery for the whole night and nothing. Valet Mode is active.
Disconnecting the battery does nothing. You need to do a RESET by holding the positive and negative connectors together for at least 10 seconds to discharge the capacitors. See Brutal's Post #3 in this thread: https://www.jaguarforums.com/forum/x...d-reset-98194/
Let us know if this worked.
Old Feb 26, 2019 | 02:39 AM
bajura's Avatar
I did it. But valet mode od still active. Does anyone know how to unlock this using the JLR SSD?
Old Feb 27, 2019 | 06:41 AM
bajura's Avatar
I bought a magnoose cable. I installed JLR SDD. I disabled the valet mode. Thanks for the suggestions. See You, Until next puzzle
Jzar
Sep 27, 2015 02:55 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
trebor12
UK & Eire
Sep 12, 2015 12:21 PM
speacock
Sep 10, 2015 12:14 AM
