2013 XJL with Beep Beep issues
Hello all.
I am getting really upset with my lovely car.
A while back i was in a hurry so i stopped the car opened the door and jumped out, while still moving a little, so the jag put it self in park and stopped, but at the same time the boot opened. 🤷♂️
And after that it looks like i am strugeling with this beep beep,
I found that There was an alarm on the right rear door, Reading the codes it was on off on off on off on off, so i changed everything There, changed start battery, and back UP battery, Key fob batteries twice, but still i sometimes get the beep beep while starting the car, stopping the car, opening door (after the autolock is engaged), while backing UP, while idelig, it is completely random, but i did not have this issue before i did my jump out while moving incident.
I also drained my battery, but i think this is the light switch failing on me at the same time, New one ordered and Will be fitted, i thought that the switch could be a part of the beep beep, but that noice is klong klong when forgetting lights 😂😂😂
I would apriciate all help on this issue, or Else i must remove the beep beep horn (where is it?)
i Have been checking the forum, but it looks like it could be anything.
A quick double beep is an error message. For example, if you lock your car repeatedly, your car will tell you "Stop Already!" by yelling "beep-beep" at you.
The first thing to do when you know that you have an electrical problem and haven't been able to fix it is to try a Hard Reset.
Your XJ is a computer on wheels. Just like your laptop or desktop PC at home, glitches happen and you can fix them with a reboot. For your X351, that's called a Hard Reset - it clears the volatile memory in the electronic modules. Disconnect the positive and negative cables from the battery and hold them together for 10 or more seconds, and then reconnect the cables.
Hard Reset X351
Good Luck!
Hard Reset X351
Good Luck!
