XJ ( X351 ) 2009 - 2019
2014 XJ Supercharged Touch Screen Rubber Surround
Old Jun 10, 2021 | 06:33 PM
mikebaker3's Avatar
Default 2014 XJ Supercharged Touch Screen Rubber Surround
After cleaning the sticky surfaces of the rubber surround for the touch screen yet again with alcohol, I am wondering if anyone can provide the part number for the rubber surround?
Is there an aftermarket replacement that uses hard plastic or a different rubber?
Old Jun 11, 2021 | 08:54 AM
XJsss's Avatar
Mine was C2D45454 and was replaced along with all the other sticky switches under warranty
Old Jun 12, 2021 | 05:15 PM
Stuart S's Avatar
Before replacing that bezel, I'd remove it and spray the rubber sections with matte black Plasti Dip. It's a small fraction of the cost of a new bezel and may work.
Old Jun 13, 2021 | 08:39 AM
mikebaker3's Avatar
Have you tried it, and can you show some photos of the repair?
Old Jun 13, 2021 | 08:48 AM
mikebaker3's Avatar
XJsss;
I found a listing for a C2D45454, but it said fitment was for a 2017.
That listing lead me to another listing for an LKQ AW93-044B88AF, which appears correct in the photo.
Old Jun 13, 2021 | 05:30 PM
Stuart S's Avatar
No, I haven't but it's what I would try first. From what I've read, Plasti Dip is inexpensive, available in matte black, sprays on, and it's easy to peel off if you don't like it. It's much cheaper than replacing the bezel.
If Plasti Dip doesn't work, I'd try matte black vinyl wrap.
There are lots of "How To" videos on YouTube for both Plasti Dip and vinyl wrap.
Old Jun 14, 2021 | 06:42 AM
mikebaker3's Avatar
Anyone with the larger screen installed? Does that surround experience the same issue? Since the larger screen still fits in the same size space, I assume that the two side pieces are smaller and hopefully made with a different material?
Old Jun 14, 2021 | 07:19 AM
XJsss's Avatar
It is my understanding that the sticky button issue was resolved in 2014 models and on as the suppliers changed the finish to the a non "rubbeerized" surface.
Old Jun 14, 2021 | 02:24 PM
clubairth1's Avatar
Community Influencer
The aftermarket big Android screen surround is made in china and is just shiny black plastic with no soft touch surface. So nothing to get sticky.
Old Jun 17, 2021 | 10:00 AM
waggybeast's Avatar
Default sticky button issue
Just as an fyi, my 2015 XJ 3.0 NA had the sticky issue, including the screen surrounds,,,,,,,,Nuetragena (sp) make-up wipes and patience got coating off.
Old Jun 17, 2021 | 10:42 AM
XJsss's Avatar
thanks for the update and went back to look at the TSB and the date range is 2010 through 2015
File Type: pdf
Old Jun 17, 2021 | 11:44 AM
clubairth1's Avatar
Yes my 2014 also had sticky buttons that were cleaned with the Neutrogena wipes. But it takes a lot of rubbing!
JDog
May 7, 2021 12:59 PM
coleman645
Sep 2, 2018 10:29 AM
Olivia731
Jul 25, 2018 11:48 AM
tinmantam
Jan 30, 2016 11:55 AM
uonott
Apr 10, 2008 03:26 AM
