XJ ( X351 ) 2009 - 2019
Creaky noise from XJ Door Seals
Old May 27, 2012 | 05:38 AM
eami001's Avatar
Default Creaky noise from XJ Door Seals
Hey people.
I have a 2010 XJ351 SWB and a particular noise is driving me crazy... I use to drive a BMW and never heard so many creaks and noises come off from a cabin so the XJ noises are really driving me crazy. One of them in particular is a creacky noise which is present all the time as I am driving. I have pin-pointed the noise to the seals around the front and rear doors of the car. As I am driving the car, there is obviously movement on the doors and with every slight movement there is mutiple creaks that can be heard from the seals around the door as they rub against the rubber seals on the body of the car. The creaks are much louder on the front doors than rear but are present on all 4 doors.
Has anyone had this issue? Is there a solution to this?
Your input would be much appreciated...
Old May 27, 2012 | 02:05 PM
RJC's Avatar
RJC
Try a "dry" silicone or silicone emulsion spray yourself, or the dealer has a similar treatment for this; if it keeps returning after treatment then the seals may need to be replaced.
Old May 1, 2014 | 09:22 AM
JB600's Avatar
I've spent ages trying to work out why the doors creak on my XJ. At first I thought it was the hollow rubber seals, then I thought it was the door striker. Today I worked it out - it's the rubber seal on the very outer edge of the door that fills the shut line between door & roof.
It can be recreated when stationary by gently pushing the top of the glass.
If the dealers apply silicon, it'll just come back after the next wash as mine always has.
Now, I've had my car treated with Superguard which gives the finish of the car a more grippy finish compared to plain paint. I think this may contribute to the friction between rubber seal and bodywork, increasing the creakiness.
I've attached a picture showing the seal that causes it. When I get time I'll t-cut the door shut and apply polish to see if a smoother finish to the bodywork helps. I'm also going to try my favourite creak preventer - graphite powder.
In the meantime, I now only have to apply some silicon to that specific piece of rubber seal, rather than plaster it on everything as the dealers tend to.
Old May 1, 2014 | 12:19 PM
Executive's Avatar
Originally Posted by eami001
Hey people.
Just realized it's an old thread
Old May 1, 2014 | 12:21 PM
Executive's Avatar
For anyone else, I was in the similar situation with my XF, ended being the sunroof seal.
Apply this stuff, usually lasts 3-4 months.
Amazon.com: SILGLYDE LUBE COMPOUND-- 8 OZ.: Automotive Amazon.com: SILGLYDE LUBE COMPOUND-- 8 OZ.: Automotive
https://www.jaguarforums.com/forum/x...e-98403/page3/
Old May 5, 2014 | 12:49 PM
tbird6's Avatar
Another vote for Silglyde. I have used it for years on all my rubber weather-stripping. Conditions the rubber and will stop the noises from the rubber rubbing on the steel.
That brand is a bit cheaper as I always have used the NAPA brand purchased from the store.
Amazon.com: NAPA Sil-Glyde Silicone Lubricating Compound 8 Ounce Tube: Automotive Amazon.com: NAPA Sil-Glyde Silicone Lubricating Compound 8 Ounce Tube: Automotive
Of course you don't use very much and a tube lasts a LONG time. My tube does not even look like what they are using now so it must be 10+ years old.
Get it a try as it is not very expensive.
Old May 20, 2014 | 01:21 PM
gregg5788's Avatar
Default Works
Interesting, this seems to work. However, the real problem is wrinkly door seals. I see the wrinkles on the passenger and driver side rear doors. These will need to be replaced I assume, to solve the problem.
Old Jan 6, 2019 | 11:39 PM
Dreamerstudio's Avatar
Luckily, this method just cured the symptoms. I had thought about opening the door panel. I’ve been using
this this
for more than a decade.
Old Jan 7, 2019 | 09:29 PM
TXFireblade's Avatar
I had the same problem on my 2012 XF Supercharged. The noise was coming from the outer door seal (felt like material). I tried the recommended products from various threads but none of them lasted. In the end I found a recommendation to use fabric softener on a BMW forum and tried that. It worked better than anything else - just apply some to a cloth and then wipe it on the furry side of the seal. it lasts about 6 months and then just re-apply. I use the unscented concentrated type but they all seam to work the same.
Old May 27, 2025 | 02:18 PM
Isoruku's Avatar
Definitely a problem for my 2004 X350. It's not always present, but it happens often enough to be irritating (right side, near the front). I've tried multiple times to locate the origin: is it the A pillar? The B pillar? Two passengers claim that the source is in front of the glove box (I'm in the US, so the glove box is on the right), thus near the firewall. I wish I could help you here, but I'm equally mystified.
Old May 27, 2025 | 07:55 PM
12jagmark's Avatar
Is a 2004 X350 the same as a 2010+ X351?
Old May 28, 2025 | 04:46 AM
JB600's Avatar
On the X351 there are 2 sources of creaking, probably exist on the X350 too...
1) The outer rubber seal you see in the A-post shutline, just in front of the door glass, when the door is closed. As the chassis flexes, slight movement cause it to creak against the paint. Just rub some silicon grease or spray along it and the noise will go. It's easy to test for too. With the door shut, just push the door frame from the inside and you'll hear the creaking. It is quite faint, so usually only heard by the keenest of ears.
2) If it occurs in warmer weather, it's most likely to be this second one. It's caused by flexing of the joint/seam in the chassis just ahead of the front door hinges. It's easy to test for if you hear it while driving. Just pull over in a quiet location, open the front door partially and apply upward/downward force on the door by hand. That recreates the flexing in the chassis that causes the joint to creak. It can only be resolved by having additional rivets installed in the joint. There is a jaguar procedure for this, but it's not widely known about and dealers seem to struggle to source it from JLR. I've had two X351's and both had the exact same issue. It seems to appear with age/mileage. I had the work done on VIN SAJAC1431GMV92809 under JLR warranty if that helps your dealer get the info from JLR.
Old May 29, 2025 | 05:52 AM
clubairth1's Avatar
Community Influencer
The A pillar noise or creak was rare. Attached are the 2 JTB (Jaguar Tech Bulletins) that outline the factory fix with rivets.
Says 2010-2014 model years.
PMKimpton
Aug 3, 2019 08:22 PM
1LowCat
Feb 23, 2016 07:19 AM
raulan
Sep 10, 2015 12:43 PM
mrplow58
Sep 9, 2015 11:27 AM
d a
Sep 3, 2015 02:34 AM
