XJ ( X351 ) 2009 - 2019
DRL, my solution.
Old Jun 27, 2018 | 09:11 AM
Sandro Felisio's Avatar
Default DRL, my solution.
Hallo you all,
after a long investigation I finally decided to make DRL light myself.
This is the result.
If someone needs specs, please ask.
Sandro
DRL fixed on the grille (closed side)
External view (closed side)
External view (intercooler side)
commander
We take relay power ACC from fuse 10A (the only red) It is a temporised power, when car switched OFF it takes 18 seconds then DRL OFF too.
DRL ON
Old Jun 27, 2018 | 09:58 AM
XJ8JR's Avatar
It looks good. I had a similar idea a few months ago but decided against it when I realized I'd be blocking a good portion of airflow to the aux radiator on the passenger side. Definitely looks good. That's really the only position where it would look stock. What brand are the units and what specifically did you hook them to in the fusebox?
Old Jun 27, 2018 | 02:06 PM
Stuart S's Avatar
Nicely done! Looks factory.
Old Jun 27, 2018 | 08:11 PM
Robman25's Avatar
These are mine, sourced from Alibaba $9.00 US free freight to NZ
Sort of fits with the J style
Old Jun 27, 2018 | 10:08 PM
Stuart S's Avatar
Nice, but posted in the wrong Forum for your car.
Old Jun 28, 2018 | 02:56 AM
Robman25's Avatar
I know but some people actually cross forums.
Old Jul 2, 2018 | 04:43 AM
Hi all,
the DRL kit is this:
https://www.ebay.it/itm/DRL-CREE-SUP...72.m2749.l2649
To get the +12V i connect the red wire as indicated to the 10A red fuse.
To get the lamp ON/OFF i connect the purple/brown wire to the white drl kit wire from headlight connector.
(I replaced the original 10A fuse with a shunted 10A fuse, you can buy here: Fusibili Uni Lamellari 10 A con Derivazione | Guidoni)
Here the pictures of inbox connection:
Inbox connection
Shunted fuse 10A
0,75mm hole glued and water isolated.
Old Jul 2, 2018 | 12:13 PM
XJ8JR's Avatar
That's great work. Thanks for the info. Might have to think about this mod. I feel like the most ideal thing would be to somehow actually replace the chrome blade itself with the LED bar. Hmmm....
Old Jul 2, 2018 | 01:04 PM
I bought an used lateral grille to try to integrate the bar inside rhe chromed flare.
i tried many options before cutting it but finally the curved profile didn’t fit the frame and itnis worst than the solution i adopt finally.
ghettomike
Sep 5, 2016 07:10 PM
RSVG
Oct 24, 2010 04:33 PM
Adam Lueb
Sep 12, 2010 01:22 PM
JimC64
Non-Jaguar Vehicles
Aug 6, 2010 08:15 PM
v8stype
Feb 8, 2009 11:32 AM
