XJ ( X351 ) 2009 - 2019
How to turn off oil change service indicator?
Old Mar 15, 2014 | 11:09 AM
davchr's Avatar
Default How to turn off oil change service indicator?
How do I turn off the oil change service indicator on a 2013 XJ? I understand the published procedure that starts with holding the rear fog light switch only works on the XF. I talked to Autoenginuity to see if their scan tool would turn it off and they said it only works on the XF.
There must be some way, other than the dealer, to turn it off. How?
thanks
Dave Christensen
2013 XJ
2003 XJR
1969 Etype OTS
1965 Etype OTS
Old Mar 15, 2014 | 07:50 PM
hawianjim's Avatar
Your dealer should have given you the first year scheduled maintenance free,mine did. I talked to my service manager regarding that oil reminder,he informed me there is no mechanical procedure for 2013 XJ though he told me if you intend changing your own oil in the future I could reset it for you no charge.Although I all ways tip him.
Old Mar 15, 2014 | 08:42 PM
Try this method and see how you get on?
You've gotta do it really quickly, hold down the reset button, key on, trip button on the end of the indicator stalk, and while holding it down press & hold the reset button. It brought up a message in German "Service cycle resetting" and after 10-15 seconds "Service Cycle Reset" and that was that.
Please report back to help others if you find it successful
Attached Thumbnails How to turn off oil change service indicator?-x350_2.7d_service_reset.jpg
Old Mar 16, 2014 | 09:57 AM
another_geek's Avatar
I don't think the above procedure will work - there is no clear/reset button on the x351
Old Apr 29, 2014 | 09:08 AM
exam23's Avatar
Can someone confirm if the following instructions work for the x351?
Reagrds,
exam2300
Old Apr 30, 2014 | 12:48 PM
davchr's Avatar
The 2013 XJ does NOT have the reset button.
Old Apr 30, 2014 | 02:54 PM
exam23's Avatar
Go figure...
The only reasonable tool I've been able to identify that may help is the x431 Launch. I will keep you guys posted.
But Jaguar is covering my annual oil change up to 2016, so no rush.
Regards,
Exam23
Old May 18, 2014 | 12:47 PM
exam23's Avatar
Go the launch x431 from new egg. Device cost 99.99, you will have to pay another $66 to download the software needed to access your car.
It will reset the service light.
Let me know if anyone need further info.
Regards,
Exam23
Old Apr 14, 2019 | 08:34 AM
Mr5Stars's Avatar
My local Pep Boys Auto Center (NY USA) resets the "OIL CHANGE" reminder for free with their high tech computer diagnostic tool, 3 minutes. I tip the guy, they love seeing "The Big Jaguar XJL" come by. My Jaguar dealership wanted to charge me $80 to reset the oil indicator reminder.
Old Apr 19, 2019 | 10:42 AM
clubairth1's Avatar
Community Influencer
Yes I am also looking for a reset tool.
Have you looked into the Autel HT200?
HT200
I found mine on EBay for $25. We have a thread going right now on how to use it.
I got the added Jaguar package and it clearly has a service reset button on the screen but so far all that does for me is throw me back into diagnostics.
I think I still need to learn some stuff as it really has a lot of capabilities and I can now see 32 different modules all throughout the car.
Old Apr 24, 2019 | 02:34 PM
RoketRdr's Avatar
Here's two other options from iCarsoft . https://www.icarsoft.com/Article/s-120-120.html
Old Apr 24, 2019 | 07:34 PM
OzXFR's Avatar
Yep, I bought an iCarsoft LR 2.0 a few weeks ago (I have had an iCarsoft i930 for years but it doesn't do resets etc like the LR 2.0 does) and used it to turn off / reset the "service required" message on the F-Type. For the last few months that message kept on popping up randomly on start-up for no good reason and it was mildly annoying.
Old Jun 26, 2020 | 07:42 PM
Jagwire XJ's Avatar
I had something similar, had the oil changed at the dealer but would get the service required message too on startup a few months later. One day I checked the oil level which was very low. Added a quart of oil to top it off and the reminder went away.
FabCat
Canada
Aug 20, 2023 10:11 AM
niner nellie
Sep 1, 2015 10:53 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
DeaconHull
Aug 31, 2015 10:09 PM
TC Johnson
Aug 29, 2015 08:55 PM
