XJ ( X351 ) 2009 - 2019
Windscreen washer - RESOLVED
Old Feb 25, 2022 | 07:12 PM
drbill's Avatar
Default Windscreen washer - RESOLVED
Hi All,
My car is a 2017 XJ 5.0 S/C. Problem is the windshield washer does not squirt water out of the jets on the wiper arms. It squirts great for the headlamp washer part, so the pump operates. Here's what I've done to troubleshoot: 1) Blown out all of the rubber lines supplying the jets. 2) Cleaned the jets themselves. I can get a good flow of air through the lines and washer jets. So, next, I disconnected the main rubber line which supplies both washer jets under the plastic cowling. I then attached a longer length of rubber line so I could operate the pump and see if fluid was even coming out of the pump and its not. Weird, it flows out of the headlamp washers, but nothing going to the windscreen washers. Any ideas?
Thanks,
Bill
Last edited by GGG; Mar 1, 2022 at 05:28 AM. Reason: Add 'RESOLVED' to thread title
Old Feb 26, 2022 | 03:55 AM
Bill,
They have separate pumps in the fluid reservoir (see items 2 and 8):
You've eliminated blocked lines and jets so it has to be a failed pump or power connection.
Old Feb 26, 2022 | 06:27 AM
drbill's Avatar
Thank you! I did not realize there were 2 pumps.
Old Feb 26, 2022 | 07:44 AM
drbill's Avatar
Originally Posted by GGG
Bill,
Graham,
I cannot see an image on your post. Do you have a link I could open in a separate window? Also, is the reservoir accessed via the passenger wheel well?
Thanks, Bill
Old Feb 27, 2022 | 01:12 PM
drbill's Avatar
Problem solved. I removed the inner fender lining, removed the pump and found the filter totally clogged with debris: mainly congealed washer fluid. Once that was cleared, everything is good as new
Old Feb 27, 2022 | 01:16 PM
clubairth1's Avatar
Community Influencer
Glad that it was a simple fix! And also great that you closed this thread by coming back and telling us what the solution was.
Old Mar 1, 2022 | 05:28 AM
Originally Posted by drbill
Graham,
Thanks, Bill
Bill,
Good to hear you fixed it.
Please send me a PM with details of the hardware/software combination you are using for forum access. The image appears both in my original post and in your QUOTE of it here!
Old Mar 9, 2022 | 02:30 PM
RD12's Avatar
Can you show how you accessed it? I'm having similar issue
Rickkk
Mar 10, 2022 08:22 AM
NTL1991
XJ40 ( XJ81 )
Sep 13, 2013 01:00 PM
billm
Sep 9, 2012 10:35 AM
