2004 XJR Radiator Leak
Old Feb 7, 2014 | 10:13 PM
soundmindryan's Avatar
Lagonia,
Do you know if that o-ring is a parts store item? I just replaced the aux pump today and have developed a leak from that exact joint. Nice pictures! You were the first person I've found to address those particular hoses and connections.
Thank you!
Ryan
Old Feb 9, 2014 | 08:38 AM
Lagonia's Avatar
Originally Posted by soundmindryan
Lagonia,
Thank you!
Ryan
I do not know if that particular o-ring has a Jaguar part number. What I would do is get an o-ring kit that you can get in hardware stores (Harbor Freight has several kits) and auto parts stores and try to match it. I have done o-ring matching in the past with good success.
Old Nov 24, 2014 | 04:59 PM
dsetter's Avatar
Originally Posted by Lagonia
Just a small update. The new cooland leak has been identified as coming from one of the heater core hoses, right at the connection. When I took the old one out, I realized that the o-ring inside the connector was deteriorated / smashed. I could have possibly gotten away by replacing the o-ring but the hoses seemed to be too soft and bloated. FYI for future reference...
I have had the same problem,hoses bloated and soft. Was going to cut old off, but the plastic is also suspect on the snap joint to the header tank.
Part number for XJR is: C2C19596
drain hose W/SUPERCHARGER
https://jaguarpartsinternational.com...iagram=4725051
1100me
Jul 24, 2023 06:10 PM
kelliott
May 31, 2022 05:26 PM
Donzi
Oct 18, 2018 12:26 AM
Numwen
Sep 6, 2015 12:30 AM
