ball joints
Old 05-14-2016, 06:17 PM
troy adams's Avatar
Talking ball joints
might be a dumb question - but here go's.
are the ball joints in a 2005 xk8 or xjr the same as a 2005 xjr v-8 super charged?
wanting to change upper ball joints with out doing whole control arm. I do know that thay were made by ford and a lot of the 2000 Lincoln ls parts fit the jxr.
thanks for your help, and I got a lot from here so far. learned a lot to!!
Old 05-14-2016, 09:16 PM
Sean W's Avatar
Received 4,188 Likes on 2,348 Posts
The ball joints can't be purchased separately. You have to buy the control arm.
I assume you have the 05 XJR? If so, 05 Lincoln LS is the same part and cheaper.
Old 05-14-2016, 11:01 PM
troy adams's Avatar
thanks, if the 05 is the same then I can replace the ball joints, in fact I have an extra set. there 14 mm if I remember and iv done a few of them. there just pressed in.
so for those that didn't know if the 05 xjr is the same as the ls then they are the same as the x300 and super 8 and can be replaced with out buying the control arm and as long as your doing them id replace the bushings to. you can rebuild the whole thing for around 36.00 for ball joint and around 28.00 for all the bushings.... a whole cheaper than a new control arm and its not but around an hour job from pulling rebuilding to replacing and another 15 min for a poor mans alignment.
Old 05-14-2016, 11:04 PM
troy adams's Avatar
and for a poor mans aliment all you need are 4 cookie sheets and some string and a bubble...very easy and 99 % of the time I'm right on when checked by a machine
Old 05-15-2016, 02:51 PM
Sean W's Avatar
Please provide a part number
Old 05-15-2016, 03:30 PM
troy adams's Avatar
part number for the ball joint?
*Jaguar Vanden Plas XK8 XKR/100 Front Upper Ball Joint Set of 2 # JLM 21380
this is for the upper control arm you just press out and press in
bushings are about 35.00
wha-la a new upper control arm
Old 05-15-2016, 04:38 PM
Sean W's Avatar
Thanks. To be clear, I was saying that the 05 Lincoln LS upper control arm will fit the 05 XKR. I have no knowledge of the ball joint interchangeability with older model Jaguars. Hope it works.
Old 05-16-2016, 06:31 AM
Fraser Mitchell's Avatar
Received 2,438 Likes on 1,943 Posts
The part number quoted is for previous cars to the X350, which are the previous steel-bodied XJ saloon, and the steel-bodied XK sports cars that overlapped the X350. The aluminium XK came out in 2006, three years after the X350 and has the same suspension arms.
Now, of course, this ball joint may well fit into the later wishbones, but is not sold as such, apart from this eBay listing.
Here is what SNG Barratt have listed for this part. Have a look at the model list.
SNG Barratt - The Ultimate Jaguar Parts Specialist
Old 05-16-2016, 07:37 AM
troy adams's Avatar
I just thru that as it was fast, but parts geek in t us has the oem ball joints for i belive 36.97
Old 05-16-2016, 07:39 AM
troy adams's Avatar
Also i have a late 2005 fxr and it is not a steel body car
Old 05-20-2016, 05:44 PM
Chuck Schexnayder's Avatar
Default Aliment
OK pal, tell us how you do it.
Some pictures would be helpful also........
Old 05-21-2016, 04:34 AM
troy adams's Avatar
next time I do a car ill take pics, but for those wondering about the cookie sheets - there used under tires so they move easy while adjusting.
Old 05-21-2016, 05:08 PM
Not a name I've heard, but I do know about the trick of putting a couple of magazines under the front wheels if you want to swivel them about whilst checking. It works like a dream too.
What I want to see if photos of fitting that ball joint you mentioned, onto the wishbone. (X350, S-type, XK from 2006, and XF up to 2015). So far there is no separate supply we are aware of, but if it matches the part that came off, then it must be correct.
Old 05-21-2016, 05:24 PM
mberman's Avatar
Try welshent.com (Welsh Enterprises). They have lots of Jag Factory & OEM parts lots cheaper than the Dealers.
I got my upper control arms from them around $400.
The upper control arm has the integal ball joint.
Also try guadinjaguarparts.com
Old 05-21-2016, 07:22 PM
Sean W's Avatar
+1 on Fraser's request. Pics please and confirm for future reference.
Thank you Troy.
Jim G
02-22-2022 07:11 AM
G1985
11-25-2019 07:12 AM
KaaNo
04-08-2016 07:52 PM
HarvesterUT
04-08-2016 06:36 PM
smgdata
03-27-2016 02:24 AM
Quick Reply: ball joints
