Both rear doors won't open...
Old Jan 11, 2018 | 10:49 AM
wesmc2's Avatar
Default Both rear doors won't open...
So I just grabbed a really clean 2004 XJ8 that has been parked for a couple years after a no start issue. I got that resolved (alternator frozen so solid it had the dealer thinking the motor was stuck) and have been driving it a couple days now.
It's doing a host of weird things I can't sort. Doors auto-lock when in drive but don't unlock unless you hit the button above the climate control. Trunk is stuck in "valet," but only the trunk. Fuel door and glove box open fine. Doing the lock/unlock with the key doesn't take it out of valet and there is no fob. It's the black key. The really weird thing is the back doors. They act like they stay locked. The plunger moves up and down but neither door will open inside or out. Pulling up on the lock doesn't help.
Anyone heard of this before?
Old Jan 11, 2018 | 12:31 PM
Lady Penelope's Avatar
Have you tried a Hard Reset ?
Old Jan 11, 2018 | 01:40 PM
avern1's Avatar
For valet mode you need to insert a non-valet key into the trunk and unlock it manually. Don't be alarmed if it doesn't unlock freely. They key is seldom used and the lock will stick. Spray a little lubricant in and work the key until it unlocks. Leave the trunk open and start the vehicle. The dash should indicated the boot is open. It is now out of valet mode. If it doesn't indicate on the dash spray the latch mechanism you may have a micro-switch that is stuck.
I will have to give the door lock situation a little more thought and check for TSB's for the locks and modules. I would recommend you spray lube the lock mechanism's for the doors that will open and that may cure the auto-unlock. Even though the auto lock is locking a micro-switch may be stuck.
Most likely in the drivers door. The doors lock and unlock in sequence so the drivers door must unlock before the passenger front and on to the back. Lube up the front locks and give it another try.
Old Jan 11, 2018 | 02:50 PM
wesmc2's Avatar
I have tried the unlock at the trunk and the doors several times with no luck. Still get the "Valet Mode" message when I push the trunk button inside or the kitten head at the trunk. This one doesn't have a green key with it, only the black one so I thought it would take care of it. Last Jag I had this problem with actually had a stuck Valet button, no luck here.
I will try another hard reset, I haven't done that since I got all the other little bugs worked out.
Old Jan 11, 2018 | 02:53 PM
Robman25's Avatar
On my 1999 308 the doors unlock from the auto lock position by simply operating the interior door handle, either passenger or drivers door.
Old Jan 11, 2018 | 06:50 PM
avern1's Avatar
You need to open the trunk with the key not the button. Look to the right hand side of the rear in between in between the Badge letters and there is a key hole. Inset the key there and use it to unlock and open the trunk. Then valet will be cancelled.
Old Jan 11, 2018 | 09:41 PM
Don B's Avatar
Hi wesmc2,
Congratulations on your 2004 XJ8. Assuming it really is an '04, it's an X350. If that is the case, please let me know so I can move your thread to the X350 forum.
Thanks,
Don
Old Jan 12, 2018 | 03:33 PM
wesmc's Avatar
I have unlocked her with the key, trunk and doors. I'm using the key every time I need in there
Don, sorry....she is an 04 ....I've had so many 308s I posted here out of habbit
Old Jan 12, 2018 | 03:36 PM
wesmc's Avatar
Rob....she makes the noise and the plungers pop up, but still no joy from either inside or outside handle
Old Jan 12, 2018 | 04:50 PM
Don B's Avatar
No problem, wesmc/wesmc2. I've moved your thread to the forum for the X350.
Cheers,
Don
Old Jan 14, 2018 | 12:50 PM
paydase's Avatar
Again, did you try a hard reset?
Also in case: is your battery new and properly charged?
john_cook12
Oct 8, 2016 12:18 AM
redpoptop
Jul 18, 2015 10:26 AM
OliverD
Jan 23, 2013 10:13 AM
'84 XJ6
Oct 11, 2011 01:32 AM
bobandgwen
May 28, 2010 09:07 PM
