Check engine light, Restricted performance , codes P0171,P0174
Old Aug 30, 2019 | 12:25 AM
rf69's Avatar
Default Check engine light, Restricted performance , codes P0171,P0174
Hello everybody:
My 2004 Jaguar XJ8 has the Check engine light on and also the Restricted performance and OBD codes read P0171,P0174 too lean both banks 1 and 2 .
I replaced the MAF sensor with an OEM Denso part #
C2S2670 and still have the codes. It has 258,000 and
I think still has the oxygen sensors from factory never
changed them . I bought the car with 52, 000 miles
and now it has 258,200 .
car drives find , spark plugs are new, also the fuel filter,
I don’t know about the fuel injectors or fuel pump but when I floor it sometimes it stalls only if I suddenly floor it to go faster.
Any advise ? Or I can just simply replace the upstream and downstream oxygen sensors , eBay has a deal going on of the Denso oxygen sensors for $365 OEM.
Any suggestions of how to proceed?
Old Aug 30, 2019 | 01:32 AM
toyman1001's Avatar
I would check for an air leak in the intake between the the filter and throttle body, A crack or a loose clamp perhaps?
Old Aug 30, 2019 | 03:47 AM
rf69's Avatar
Thumbs up
Thank you
Old Aug 30, 2019 | 07:05 AM
JagV8's Avatar
What do the fuel trims show?
BTW there a LOT of threads about what to measure & when etc.
Old Aug 30, 2019 | 09:47 AM
Wingrider's Avatar
Good chance if it is not any of the basic plastic intake piping & smoke test shows nothing.
Those eight pesky hidden intake manifold gaskets are what your looking for.
As for the oxygen sensors, many consider them a wear item, much like spark plugs.
Use the stock oxygen sensors, which i believe are Denso's.
Old Aug 30, 2019 | 10:56 PM
rf69's Avatar
Watch my video ,, I found a vacuum leak , it is a broken hose that comes out from the back of the throttle body and goes to the base of a connector on the injector rail .
I need the name of that part , any idea?
Old Aug 31, 2019 | 01:22 PM
rf69's Avatar
The vacuum leak was a broken thin hose that comes from the back of the throttle body and connects to the Fuel injection pressure regulator sensor.
the hose broke at the base where it connects to the sensor located on the fuel injectors rail.
Old Aug 31, 2019 | 01:27 PM
rf69's Avatar
Old Aug 31, 2019 | 01:34 PM
rf69's Avatar
I got it from Barrett
The vacuum leak was a broken thin hose that comes from the back of the throttle body and connects to the Fuel injection pressure regulator sensor. And a Vacuum elbow that attaches to the sensor.
The hose broke at the base where it connects to the sensor located on the fuel injectors rail.
Old Sep 1, 2019 | 09:05 AM
JagV8's Avatar
Nice find!
Are the trims now OK?
Old Sep 2, 2019 | 03:00 PM
rf69's Avatar
I do not know but The check engine went away. I am wondering if I should replace the oxygen sensors since they never have been replaced.
My jag has 258,200 miles on it.
2004 Jaguar XJ8
Old Sep 2, 2019 | 06:24 PM
Mark in Maine's Avatar
I chased a lean condition with no vac leaks forever, when it ended up to be O2 sensors. Fixed my problems and brought my trims back to normal. Check the voltage on them with a live data scanner prior.
mpodurgiel
May 30, 2017 02:00 PM
nothing4u
Apr 27, 2016 01:13 PM
mjlaris
Jul 7, 2014 03:32 PM
loblue
Aug 1, 2011 12:17 PM
Convoymotors
Oct 6, 2010 12:09 PM
