climate control display temp
Old Jun 18, 2013 | 11:47 AM
mhamilton's Avatar
Default climate control display temp
This is going to sound very strange, but I think my climate control went from displaying "72 F" to "72.0F" for the interior temperatures (no nav). I've seen the ".0" in photos of other cars, but I swear mine did not show that before. I was driving yesterday and it caught my eye because something was just different.
Am I loosing it? Or is there some key-combo that I inadvertently switched the decimal back on? I tired cycling through F/C, always keeps the decimal.
This isn't anything that bothers me like it's broken, I just swear it never used to show that decimal point before.
Thanks,
-Michael
Old Jun 18, 2013 | 04:59 PM
Fraser Mitchell's Avatar
You can set it Centigrade or Fahrenheit on the vehicle setup screen, so you could try to reset by going to C, then back to F. FWIW my display only shows whole degrees, (Centigrade - for my missus who is Italian !!). Her VW New Beetle give one decimal point as did my Rover 75.
Old Jun 18, 2013 | 05:43 PM
esloser's Avatar
My internal temps show the decimal. They dont increment in deimals though. The external is a whole number though.
Old Jun 18, 2013 | 05:50 PM
Sorry, I was too quick in responding. Yes, the internal settings allow half a degree, so one can set 22.5 degrees C, but not tenths of a degree.
Old Jun 19, 2013 | 06:56 AM
mhamilton's Avatar
I think it may have always had the decimal point, but can't for the life of me figure out why it looks so weird all of a sudden. No matter... thank you for the replies!
Old Jun 19, 2013 | 02:13 PM
Sarc's Avatar
I think it may be this...... when in "F" mode, you don't get a decimal place and the settings are in absolute degrees F
When you are in "C" mode, you get the half decimal, ie .0 or .5
So maybe you were used to seeing the display in "F" and now it's in "C"?
Old Jun 20, 2013 | 12:48 AM
slmskrs's Avatar
From: San Francisco Bay Area (south bay), California USA
So, slightly off topic, but where is the external temp sensor located on an X350 (we picked it up recently and I'm just learning about it)? Our '97 xj6l seemed to be extremely accurate and rapidly changed as the outside temperature changed (it would only be incorrect when hot and sitting parked, but would change quickly to the correct temp after driving it for a few minutes. The '05 sensor seems to be very slow to respond and doesn't always get to the correct temp (seems high). Just wondering where it is so I can see if it is somehow blocked, etc.
Old Jun 20, 2013 | 08:12 AM
mhamilton's Avatar
I never use degrees C, wouldn't mean much to me outside of the lab Think it has just been one of those weeks... the other day I went to change my radio station and turned on the blinker...
It's located in the lower air scoop right next to the LH fog light. I noticed mine is slow to respond and sometimes reads a few degrees high. There is definitely programming built in to limit rapid swings in temp being displayed. My Cadillac had that explained in the service manual, they don't want you to park and then get in the car 10 minutes later and see 130 degrees from the engine heat, so there's criteria that temp won't increase unless you're moving > certain speed, but it can drop immediately, etc. If I drive into a parking garage mine will drop 10-20 degrees immediately.
EDIT: sorry, meant the RH fog light (passenger side)
Old Jun 20, 2013 | 04:27 PM
slmskrs's Avatar
Thanks. I'll check it this evening when my wife gets home. For someone who thinks it looks like a buick, she is no longer hesitating to hop in the X350 rather than the Expedition (especially since the x350 gets at least 2X MPG over the Expedition!).
Of course, if we didn't have the lower timing chain tensioner issue on the X300, she'd drive that instead.
2001 White XJ8
Feb 25, 2021 05:02 PM
abonano
25
Sep 25, 2015 10:43 AM
Johnken
Sep 15, 2015 05:46 PM
texaspete
Sep 10, 2015 08:34 AM
tberg
Sep 7, 2015 07:32 AM
