Dead Screen after NAV Update attempt
Old Dec 16, 2012 | 10:21 PM
200Volts's Avatar
Default Dead Screen after NAV Update attempt
I tried to update my NAV DVD. It was not reading the new DVD, so I put the original back in. Now my NAV, CLIMATE, RADIO etc screen is black. Nothing.
I tried redoing the NAV update, even disconnected that battery. Nothing.
HELP !
2006 XJ8
Thx.
Old Dec 16, 2012 | 11:53 PM
gmcgann's Avatar
How do you know it was not reading the new DVD? Where did you get it? Turn the key on, put the new disc back in and wait at least 30 minutes. If it fails, put the original disk back in and wait 30 minutes. It will recover.
Old Dec 17, 2012 | 10:11 AM
200Volts's Avatar
It kept asking me to insert the DVD, but it was already in. I put the original DVD back in, let it sit for 45 minutes. Still a black screen, and now the DVD won't eject! I'm probably going to the dealer tomorrow.
Old Dec 17, 2012 | 10:24 AM
steveinfrance's Avatar
I see you've found the right thread - looks like you need to make a software disk.
I don't know if the file in this link
https://www.jaguarforums.com/forum/x...e5/#post524648
will work for your system - that one is for Denso satnav.
Old Dec 17, 2012 | 10:53 AM
gmcgann's Avatar
Where did you get the dvd? These units are pretty foolproof. You can't kill one by putting in a wrong disc. Even if you put in a bad disc and screwed up the programming it should still reload the operating system when you put a good disc in.
Old Dec 17, 2012 | 04:29 PM
200Volts's Avatar
While searching the web, I found one that worked on Denso Jaguar, Ford or Cadillac. I borrowed my friend's 2011 Cadillac DVD to see how much better it looked, before buying one - yes a stupid thing in hindsight, I thought if it didn't work I would just replace with my factory 2006 DVD. It kept asking me to put in the disk, 3 times, after I pulled it out and put it back the 3rd time the NAV screen went black, so I assume it messed up the NAV ECU. I downloaded the .KWI file, burned it to a 2 layer DVD, but nothing happens for 45 minutes after I put it in, the turn off the car, then only to ON.
---I read about the "secret" diagnostic screen, that can force a s/w update. But I'm not sure how to pull that screen up (key on, then Nav-Up Arrow on Blower, repeat 3 times,etc.). Any advice would be appreciated.
Old Dec 17, 2012 | 09:32 PM
gmcgann's Avatar
The disc contains not only the navigation maps, but the operating system, which will be different for different cars. The firmware in the system just looks for newer software when the disc loads, but that's all it does. You need an actual Jaguar disc. I haven't heard of anyone bricking the unit by putting a different dvd in it, but perhaps something is preventing yours from loading the old software. For one thing, you have the sequence wrong. If you turn the car off after you put the disc in you WILL cause a failure. You NEVER interrupt an update. You also say you turn the key "only to on." Do you mean the first click of the switch? It needs to be in the second click.
Start the car. Put the old DVD in the drive and leave the car running for 30 minutes. It should load. If not, you can try a new disc. You can get one here: 2012 JAGUAR XJ, X&S-TYPE GPS NAVIGATION MAP UPDATE DVD for sale Several people have used this with no problem. It's a copy of a genuine Jaguar disc so as long as it isn't physically damaged you're good. I would recommend making a copy when you get it just in case something happens to it. You need to rip it as an ISO image which you can then keep on your hard drive, or burn the image to a blank disc and keep it in the same place.
I have seen places on line where you can download these images, but there are no guarantees that they will work or don't contain malicious code. They are, after all, pirated copies. So is the ioffer disc, but you have plausible deniability there and you are probably safe as the consumer. Start uploading it to others and that's a different story.
Old Dec 18, 2012 | 11:35 AM
200Volts's Avatar
gmcgann, thanks, but that did not work either. I start the car, put in the factory DVD and waited 45 minutes while the car is running . still a black screen on the head unit. my dealer suggested removing both battery cables for this procedure, which I did before starting the car. I also noticed a deep scratch on the factory DVD. hopefully whatever the dealer uses will fix the problem, it's going there tomorrow.
-Just realized- I burned the Loading.KWI file on a single layer DVD. I'll reburn on a dual layer DVD and try it again (note to all, dual layer DVDs have over 8GB capacity - single layer DVDs are around 4GB).
Old Dec 18, 2012 | 09:46 PM
xjrguy's Avatar
-Just realized- I burned the Loading.KWI file on a single layer CD. I'll reburn on a dual layer DVD and try it again (note to all, dual layer DVDs have over 8GB capacity - single layer DVDs are around 4GB).
I think you've corrupted the base bootstrap software in your NAV unit. I don't believe the software on the data DVD can straighten that out. Your dealer will probably have to dig up the NAV re-flash CD with the Part Number JTP1073. IF they still have it. It's the only way to recover a corrupted NAV. It came out in 2005 and was supplied one to a dealer, and can no longer be had. I have guarded ours with my life.
One other note, only the ORIGINAL CD will function in the NAV, some time ago I tried to copy and archive the original, no copy would ever work. I tried different copy software, different CD brands and types; nothing worked. A copy just will not work like the Map DVD copies will.
That CD will have to be put in and the ignition left on for 20-30 minutes. If that recovers the unit and you get to a white screen or a Leaper, you should be able to load the current software from your Map DVD and be good to go. If that doesn't recover it, there really isn't any other choice but an exchange NAV unit.
Good luck!
Old Dec 18, 2012 | 10:19 PM
200Volts's Avatar
Steve,
What general part of the country are you located in?
Old Dec 18, 2012 | 10:33 PM
xjrguy's Avatar
Indianapolis.......top right in every post.
Old Dec 18, 2012 | 10:50 PM
200Volts's Avatar
XJRGUY,
Thank you for the input, that's what solved the problem. You're an expert!!!!
Greg
Old Dec 19, 2012 | 10:49 AM
gmcgann's Avatar
You would have to copy the disc as an image, i.e., iso, for it to work.You can't just copy the files.
Old Dec 19, 2012 | 10:55 AM
xjrguy's Avatar
Absolutely correct........covered!
Old Dec 21, 2012 | 10:24 PM
xjrguy's Avatar
XJRGUY,
Greg
My pleasure, glad you recovered your system. It's nice when a seemingly catastrophic gut check like that can be corrected without major expense.
Thanks for the shout out!
Cheers,
trosty
26
Dec 18, 2022 06:40 PM
08292
Jul 9, 2018 01:44 AM
captbob73
Oct 24, 2015 05:49 PM
aadjei
Sep 25, 2015 08:51 AM
texaspete
Sep 10, 2015 08:34 AM
