disconnect an Arnott air fitting
Old Aug 26, 2015 | 08:13 PM
mhamilton's Avatar
Default disconnect an Arnott air fitting
Help! I replaced my front springs with the new-manufacture Arnott units. First everything was great, but took it for a drive and noticed the front right was dropping while the front left was okay.
I am nearly sure the issue is the connection at the air line. These new units don't use the olive and compression, they use something like a Sharkbite where you just press the pipe in. I (foolishly, in my rush) did not cut off the end of the air line to remove the grooved section where the olive was. How do I get the line back out?! Would really love to fix this without having to wait to call Arnott tomorrow morning.
Thank you in advance!
Old Aug 26, 2015 | 09:16 PM
cjd's Avatar
cjd
I pushed the hose in and then turned the fitting clockwise to lock it. Have you tried turning the fitting ccw to release?
Old Aug 27, 2015 | 09:27 AM
mhamilton's Avatar
Thank you--I believe you're right. I didn't try that because I wasn't sure how the fitting worked. But heard back from Arnott this morning and he said yes, unscrew the fitting, there's a collet inside. Similar to the OE fitting.
Will try that, cut off the end of the pipe, reconnect and go for attempt #2. Fingers crossed that's the only issue.
Old Aug 27, 2015 | 09:59 AM
cjd's Avatar
cjd
They should have a better description in the instruction sheet. It is different than the OEM, and all they say is " insert the hose".
Old Aug 27, 2015 | 12:22 PM
mhamilton's Avatar
Yeah, the instructions were not too useful. The tech support at Arnott was very helpful and even sent me a drawing. It's called a "Voss fitting" and it's very similar to the OE compression ring. I opened up the offending one, and sure enough the collet had fallen right into the old groove in the pipe. I slid it up the hose, cut off 2mm, reinstalled, and so far so good!
I will make sure it's all good and then might redo the left side just to be sure everything is 100% leak free.
I do have to say, I agree with everyone else that praises these new Arnott units. The ride is so much better and the handling is phenomenal. Feels like a new Jag again. The old shocks had gotten so worn out that the ride was wallowly and uncontrolled.
Old Aug 27, 2015 | 01:54 PM
arnottdoug's Avatar
Former Sponsor
Default Arnott Technical Service Bulletin - Air Fitting
Sorry for the confusion. Below is a link to the Arnott Technical Service Bulletin (TSB) on Air Fittings. We now include it with each part that has a VOSS Air Fitting.
http://arnottinfo.com/manuals/TSB_1_11_REV_2.pdf
Here is the TSB that comes with the Arnott New Front & Rear Air Struts: http://arnottinfo.com/manuals/TSB%20_7_A.pdf
Old Aug 28, 2015 | 04:55 PM
cjd's Avatar
cjd
I've had my car since new...it never rode as nicely as it does with the Arnotts.
Old Sep 13, 2015 | 09:24 PM
hafren's Avatar
Doug,
Just read this post and wonder if this is the source of my air leak? I fitted 2 new Arnott remanufactured air struts recently but without this TSB information I just fitted the existing jaguar fitting into the new struts. If the car is not used for 4-5 days I notice the front drop ~1". Should I be following the TSB? I still have the fittings that came with the Arnott struts.
Just to confirm
  1. install these fittings into the strut at a torque of 5Nm
  2. cut the old olive off the air line and push into fiitings
Old Sep 15, 2015 | 05:13 PM
arnottdoug's Avatar
Former Sponsor
Yes, it may help to replace the air fittings. Contact our tech support department if you have questions. 321-868-3016 X 100 (800-251-8993)
aholbro1
Dec 29, 2024 06:46 PM
1100me
Jul 24, 2023 06:10 PM
RoyLittle0
May 25, 2023 02:38 AM
trosty
26
Dec 18, 2022 06:40 PM
smith356
Oct 7, 2015 06:41 PM
