DSC NOT AVAILABLE
Old Oct 27, 2008 | 10:49 AM
JagMaster's Avatar
Default DSC NOT AVAILABLE
I ve been getting the DSC NOT AVAILABLE message for a while now, but it happens once in a month so I dont care about it that much. But I do curious about why it happens and whats wrong actually? Anyone have the same issue?
Old Oct 27, 2008 | 04:03 PM
veffremov's Avatar
Default RE: DSC NOT AVAILABLE
It means the DSC computer detects and error and shuts off. The source could be quite a number of things - speed sensors on the wheels. Yaw rate sensor. Bad cable connection. Bad DSC module. Even bad wheel alignment may cause the erros. The DSC module reads a whole bunch of data and analyzes it in real time. If it detects inconsistencies in any of the data it disaplay this error. For example yaw rate sensor says your car is turning left, but wheel speed and turning wheel position dont agree.
If you can pull the compiter codes off it may give you a clue where to look for the problem.
The problem codes are stored in the computer even if the message is not on display. It is tricky to diagnose if the problem is not reproducable.
Old Oct 27, 2008 | 08:17 PM
JagMaster's Avatar
Thanks ,I'll stop by at the dealer and make them check it. I hope its not a serious problem
Old Oct 28, 2008 | 06:40 AM
mosesbotbol's Avatar
This happened to me once as well.
Old Oct 28, 2008 | 08:38 PM
veffremov's Avatar
As far as I know it is not serious in terms of "your engine will not blow up". There is always the reduced safety when the DSC is off. In terms of cost I have no idea, but as it is difficult to diagnose you could end up replacing a few things before getting to the right one.
It happened to my car as well, but then it dissapears, so I'm hesitant to go to the dealer in the current state. I'll wait till it starts comming up in a more consistent way.
If you have warranty left. Definitely go to the dealer.
Old Oct 29, 2008 | 02:44 PM
JagMaster's Avatar
Well I got my Jag in July and it happened only twice so right now everything looks fine but if it happens again I'll definitely take it to the dealer. My warranty is expired but I have an extended warranty from service shield. They dont cover anything tho lol.
Old Oct 30, 2008 | 04:54 AM
veffremov's Avatar
I wish there was an easier way to read the DSC computer codes. Going to the dealer for just that is waste of 100 bucks.
There are some handy USB>OBD2 adapters, but the software can read only ECM data.
Old Oct 30, 2008 | 11:03 AM
ken@britishparts.com's Avatar
If you have an idependant Jag shop, they should be able to read codes.
radiatn
Jul 2, 2021 04:45 PM
kingdom worker
Nov 14, 2020 03:47 PM
goges
Oct 5, 2015 04:53 PM
3lvis
Oct 1, 2015 01:56 PM
