Engine mount vs. Transmission mount
Old Apr 27, 2020 | 07:58 PM
JaguarXKR's Avatar
Default Engine mount vs. Transmission mount
Hi All,
Ever since I purchased my XJ in October, I have noticed a slight vibration being translated to the occupant compartment. Most noticeably when at a stop light. As soon as I lift off the brake and start to accelerate it seems buttery smooth again. Is there a way to know which mount (or if anything else should be looked at) is starting to go on my X358?
Thanks for your help!
Old Apr 27, 2020 | 08:40 PM
abonano's Avatar
Originally Posted by JaguarXKR
Hi All,
Trans mount is more suspect than the engine mounts and easier to tackle.
Old Apr 28, 2020 | 06:32 AM
mhamilton's Avatar
I have replaced all 3 (2 engine, 1 trans) mounts on my vehicle over the years. Telltale sign is the hydraulic oil in the mount having leaked out. Will look like very dark red oil. In one case I had found a puddle of what I thought was power steering fluid on the belly pan. And I could see the oil on the trans mount had leaked all over the crossmember.
If you don't have any evidence of that, you can have someone help brake torque the engine in D and R and watch the motor mounts to see if one or both has excessive movement.
Old May 17, 2021 | 06:45 PM
JaguarXKR's Avatar
I finally got around to replacing both my engine mounts and transmission mount. The slight vibration is still slightly present. Anything else I could try?
Old May 17, 2021 | 07:18 PM
xalty's Avatar
check plug condition/gap, and smoke check for vacuum leaks
Old May 17, 2021 | 07:35 PM
Panelhead's Avatar
Check for vacuum leaks.
Old May 18, 2021 | 07:17 AM
JaguarXKR's Avatar
Thanks! Are there common areas for vacuum leaks on the 350/358?
Old May 18, 2021 | 09:41 AM
Panelhead's Avatar
The vacuum lines. Run a fuel trim.
Old May 18, 2021 | 09:43 AM
Panelhead's Avatar
The supercharged cars are harder on the mounts. I have replaced one engine and the transmission mounts.
Old Jun 20, 2021 | 09:46 PM
JaguarXKR's Avatar
I plan to start with replacing my spark plugs in the near future, instead of just checking gap. Should I replace my coils or reuse my current ones?
Old May 19, 2022 | 05:02 AM
Petz's Avatar
Whining broken Alternator in addition to the 2 oem engine mounts and oem engine transmission mounts will be changed very soon on my 2003 xj8 with 341000km .
only have a slight wiggle when I start the engine cold thats gone after a couple of seconds.
Pan, filter, oil ,sleeves, have been changed recently with zf kit
hope for some improvement
Nedoerr
Nov 22, 2022 08:01 AM
kazi
Feb 24, 2020 08:46 AM
Higgins
Feb 20, 2019 05:50 PM
AlbBolivar
Jun 21, 2015 10:28 PM
martin fothergill
Mar 19, 2010 09:13 PM
