Fuel pump module cross reference?
Old Jul 17, 2020 | 03:15 PM
gmcgann's Avatar
Default Fuel pump module cross reference?
I think I've finally solved my fuel pressure problem. Apparently the XJR uses a second fuel pump driver module for the second fuel pump, and mine appears dead. That would explain why the car runs fine below about 75% throttle, but the fuel pressure goes away after that. I checked with two Jaguar dealers and they both told me the same thing - that the part is discontinued and unavailable. They both said I'd probably have to scrap the car if I couldn't find a used one.
I don;t like buying used electronics, and this looks like a Ford part anyway. The Jaguar part number is C2C23781, and the part number on the module is 2W9F 9D372 AB. There is also a Ford logo. Does anyone know of a cross reference for this?
Old Jul 18, 2020 | 06:50 PM
paddyx350's Avatar
I picked up an xjr fuel pump module on ebay.
I'll have a look at the part number in the morning and post
Old Jul 21, 2020 | 03:24 PM
gmcgann's Avatar
I'm sure it's the same part number as the one on mine. It's a Ford part and it almost certainly fits vehicles other than the Jaguar, but which ones? It's no longer available through Jaguar but maybe it is, or a suitable replacement, through Ford.
Old Feb 6, 2026 | 08:50 AM
Andygt's Avatar
Default Ditto
Hi, did you ever resolve this? I have the same issue. Thanks.
Old Feb 6, 2026 | 09:43 AM
clubairth1's Avatar
Community Influencer
What car do you have?
Old Feb 6, 2026 | 10:10 AM
Andygt's Avatar
2003 x350 xjr
Old Feb 7, 2026 | 10:35 AM
clubairth1's Avatar
I am not sure but I "think" this Dorman part might work for your car? You have the 4.2L SC V-8 and while the Dorman application chart does not show the XJ with the 4.2L SC engine it does cover the S-Tpe R which also had the 4.2L SC engine. Plus this also fits the 3.0L V-6 as well as a number of Fords.
Does your module look like this? I don't know where this module is located in your car either but it's probably in the trunk somewhere.
If so I would take a chance and see if it would work.
Here is the plug to match up.
They are expensive at around $150 but they are obsolete from JLR and Ford. I did find a brand new one for $50 on EBay.
Dorman Fuel Pump Module
Up to you but a used one could be a solution as these are not terribly failure prone. But if it were my car and I could get a new module for $50 I would take it now!
Old Feb 7, 2026 | 04:27 PM
Andygt's Avatar
Thank you. It looks very much like mine.
Old Feb 8, 2026 | 07:01 AM
clubairth1's Avatar
Can you do us a favor? With the cars getting older everyday and parts going obsolete please report back if that part works or not. A picture of your old module with the part numbers on it would be a great help. I know you need a few more posts before you can upload pictures. I think 10 posts are required.
That could be a critical part in keeping the cars on the road. Plus with Dorman involved the parts will be much cheaper and widely distributed. Now I have had some problems with Dorman and don't consider their stuff equal to OEM parts but if that's all that is available. Well we are stuck using it.
Old Feb 11, 2026 | 10:57 PM
xalty's Avatar
W9
Jaguar XJ
F
Fuel Delivery/Electronics
9D372 - Fuel Pump Driver
They put these FPDMs in like 10 billion cars the difference is part numbers is because of the bracketry.
Old Feb 12, 2026 | 03:41 AM
Andygt's Avatar
Thanks 👍
Old Feb 12, 2026 | 08:10 AM
clubairth1's Avatar
Thanks Xalty!
So I did find the correct module and they are very common. That's good to know.
DanTindell
Oct 18, 2020 06:35 AM
al 350i
Nov 2, 2016 08:37 AM
Dewd
XJ40 ( XJ81 )
Apr 17, 2014 08:48 AM
jaguarlars
Jul 2, 2013 11:31 AM
