Greeting from the neighbors and needs a couple of advice on newly acquired 2004 XJR
Hi Folks, A long time Jaguarian from the XK8 world, I just got myself a 2004 XJR 150K miles for cheap, runs well except for a few things:
Control arm totally ripped out...easy...I am replacing those
AC doesn't blow cold ...but I'll get a shop recharged it and hopefully it's not leaking.
Will change tranny fluid and filter with Mercon SP
Change out supercharger oil.
Here are the section that I need advice on:
1. I noticed pretty bad oil leaks that would trails driving from the driveway to garage from my research about this car, the oil pan gasket is notorious for leaking, however when I look underneath, is that the upper Oil pan Gasket leaking as well??
How hard is it to fix? is there any direction on this forum?
2. The last picture shows Supercharger shows a lot of grimes from what appears to be gaskets...looks simple to change (4 bolts) can you guys confirm this? also any direction on part number would be much appreciated
Thanks Guys...as always I can count the Jaguar forum to help me out :-)
Notice the upper part of the oil pan, looks wet
Look at the gaskets on the SC
I am replying to your post but I don't have any answers except:
The oil above the filter could well be from the supercharger leak at the top of the engine.
I suggest that you may want to have the engine steam cleaned (not water) and then
you will be able to see more clearly what you are dealing with.
The people who do car detailing may be able to advise you on this to avoid any electrical problems.
Zidjan, first of all congratulations on the buy.
Its hard to tell by just these pictures what the issues could be, but I will try to answer your questions as best as possible.
-It does seem like you have oil leaking from above the oil pan for sure. Where its coming from, could be several places. If you are mechanically inclined, it wont be anything terrible. Once these cars get up in miles, a lot of the rubber gaskets become hard and brittle and will leak (any car, really). The cost for the gaskets wont run too much either if you source them on Ebay. If you have a leak coming from your valve covers, supercharger, vac hoses, you should see bank 1/bank2 too lean codes. If you don't have that, and your fuel trims are normal, then you might be ok. !!!The first thing I would start with is cleaning the engine up safely like meirion said. Once its clean you will be able to identify the origin of the leaks when they start to leak again!!!!
-These are simple to change:Manufacturer Part Number:
Will run about 90 bucks for the set.
AJ86892
Yes Thank you for the advice, I am moderately handy with cars...I have an XK8 that I worked on myself as well...I am just getting to know the XJR and I appreciate the advice....I will clean the underneath pronto hopefully I can find the source soon.
I'll be back to report any findings and updates
Received 2,183 Likes
Upper control arms..the ball joints are totally ripped ..the rest of the rubber parts seems ok although I am sure it could use a total overhaul..but I am focusing on the leaks first.
If the steel balljoints are OK, why not just replace the rubber boots ? There are internet suppliers of these, but you do need the measurements of each end of the boot.
paulsdunford
01-25-2018 05:41 AM
hdsg
09-15-2010 12:16 PM
Keven
05-27-2009 05:46 PM
