Help Needed
Old Feb 28, 2024 | 03:38 PM
Jag Dog's Avatar
Default Help Needed
Good afternoon everyone. When I was given my 07 xjr jaguar in October, one of the issues that I had with it is that the windows will not come down. I've done what I know to do but I'm not able to get the windows down or to even move at all. The red light on the master switch on the driver side is lite up red so there is power going to the window switches. I have checked them with test like as well. I have changed the switch but that didn't work either. So can anyone on the thread tell me what I should do next? Oh I'm getting a code in the GEM saying short to ground in passenger side window. It doesn't say which door window though.
The second thing is the wipers only work on high. None of the other settings work. How can I tell if this is a motor issue, a relay issue or the switch? Any help that anyone can give me on these issues would be greatly appreciated.
Old Feb 28, 2024 | 06:13 PM
abonano's Avatar
Sounds like a common grounding issue. Check all body grounding points but be careful. They are delicate due to the aluminum body.
Old Feb 29, 2024 | 05:50 AM
ctsemicon's Avatar
I'm looking at schematics for door windows; short-to-ground would lead me to think (one of) the window motor assemblies has the short to ground. Each window motor assembly has a ground wire in the connector - its the black one. Checking for short means removing the door card, which is a PITA but not too technically difficult. I would start with front passenger door, disconnect connector at motor assembly, and see if short goes away. If code specifically says "passenger" that refers to front door (rear would say rear).
Old Feb 29, 2024 | 09:04 AM
Wingrider's Avatar
As for grounds, starting with the major ones, easier, & it might solve things.
Old Feb 29, 2024 | 11:57 AM
Jag Dog's Avatar
Good afternoon Ctsemicon, I hope this email finds you with all things being well on your end. So I went back and checked the code and yes sir it's passenger window that is short to ground. The code is B2196: Passenger Door Window Glass up/down Power Circuit-Short Circuit To Ground. So I will take your advice and remove the door card. Then disconnect the connector at the motor assembly and see what I get. Now if it goes away, what is next, do I plug it back in or how do I further go about trouble shooting? And if it goes away, do you think the other windows will begin to work?
Do you have any knowledge on my wiper situation? If so, please share.
Old Feb 29, 2024 | 12:00 PM
Jag Dog's Avatar
Good afternoon Wingrider, I hope all is well on your end. Hey by chance can you please tell me where the major grounds are? I've seen the one from transmission to frame but where are the others. I've been looking but I guess they are not where they normally would be on American made cars and if they are, mine are gone. So maybe you can point the major ones out for me.
Old Feb 29, 2024 | 12:03 PM
Jag Dog's Avatar
Abonano,
Top of the afternoon too you. Hey can you help me out and give me specific locations of grounds on this car? I have not been able to locate any other than the small ones behind the light fixtures and the major one under the car from the transmission to the frame.
Old Feb 29, 2024 | 01:23 PM
h2o2steam's Avatar
This information is clipped from the schematic diagram which you can download your own copy from JagRepair.com - Jaguar Repair Information Resource
Old Feb 29, 2024 | 03:07 PM
Jag Dog's Avatar
Good afternoon H202steam, I hope all is well on your end. Thank you for the diagram of the ground points. Can you please share with me which ones are considered the major ground points, or can anyone assist on this matter?
Old Feb 29, 2024 | 04:30 PM
Wingrider's Avatar
Looks like ctsemicon may have pointed the right ground.
Was thinking it might be one under the hood,
Old Nov 4, 2024 | 03:59 PM
Jag Dog's Avatar
Good afternoon everyone, I pray all is well. The 07 XJR that we were given is mechanically doing well. Still have some electrical issues that we have not been able to resolve so we still need some help. So my windows will not go up and down and right now that's one of my biggest issues. One code that stands out is a pending B2196 passenger door window glass up/down power circut -short to ground. Any assistance in this matter would greatly be appreciated.
Old Nov 6, 2024 | 09:26 PM
h2o2steam's Avatar
Has the fuse F46 (25 Amp) been blown in the passenger junction fuse box?
That fuse specifically feeds the passenger front door window assembly.
If the fuse is blown, then what you can do is take a digital multi-meter on low ohms setting and measure from the load side of the fuse carrier to earth. This is to see if you can measure a very low resistance.
If you get a reading that is under 100 ohms or lower, then I would be suspicious of a potential cabling issue, or a window motor assembly that has developed a problem.
You can verify the reading by repeating the measurement to the front window motor by removing fuse F37 (also 25 Amp) and seeing what resistance you have.
Technically you should not be measuring the motor winding with that initial test as there is a relay and motor driver circuit incorporated within the window motor assembly that should only connect the motor load when commanded to by the appropriate door switches.
To eliminate the motor assembly you may need to remove the door panel and unplug the 8 way connector to the motor assembly and see if the low resistance disappears.
If you find high resistance, then all you can do is try another fuse to see if it immediately blows again immediately or when you try to operate the window. If it does then you probably have a fault within the window motor assembly.
Those fuse numbers might be reversed depending on whether the schematic was written for LHD or RHD.
4catstudio
Jul 27, 2022 09:33 PM
Spyhunter2k
May 21, 2022 11:33 AM
10 XF Premium
Oct 11, 2018 11:03 AM
pzjaguarv12
Oct 19, 2014 02:28 PM
Rutty
XJ40 ( XJ81 )
Jan 20, 2014 04:06 PM
