Leaky hose causing steamed windows??
Hello Forum,
RE: 2006 XJ
In these cold days, it seems that every time I park the car, go in a store, I come back to very steamed windows, so bad that I need a cloth to wipe the moisture off. Could it be a broken hose or the such?
Thank you
RE: 2006 XJ
Thank you
Is there a smell or film to the condensation on the windows? That may indicate a coolant leak, other wise it could be just water coming in from a bad seal (mirror, door, etc.). You could try to test with a spray hose on suspect spots to see if it leaks.
Bad news would be a heater core as I do not recall any hoses entering the cabin area. It could be a heater hose (behind the engine, passenger side) that could be spraying into the cabin.
Good luck
Good luck
I am about to clean out the cabin/pollen filter compartment tomorrow but will check the drain there and would like to check the connections to the ECU. Should I disconnect the battery before doing so?
Thanks again folks
Thanks again folks
Well with some warm weather today, I took the cabin filter casing apart and all was dry as a desert including the sponge lined inlet to the heater vent. The drain was clear also. Checked the ECU connections as well.
The floors are all dry too.
Reverend Sam
Mar 9, 2026 01:08 PM
