My transmission removal & rebuild
This thread is for anyone who's facing a misbehaving transmission and are thinking about removing it yourself. Ive been having consistent transmission issues (namely - 3-4 squawk noise) See threads below for history.
https://www.jaguarforums.com/forum/x...ditive-198143/
https://www.jaguarforums.com/forum/x...ts-end-190552/
https://www.jaguarforums.com/forum/x...th-6th-211104/
Its finally reached a point where any normal to heavy acceleration in 4th 5th or 6th and the transmission makes the squawk noise and slips badly. From my research this appear to be a failed/slipping 'E' Clutch. It is time to remove the transmission and get it rebuilt.
The removal was very straightforward. The biggest thing is securing the driveshaft and labeling the flange bolts. One of the dowels on the trans was stuck and took some 'persuasion' to remove.
Total time was 4-5 hours.
The picture below shows my makeshift transmission jack (lol) and a piece of ductaped 2x4 that is used to wedge in between front crossmember and oil pan (per removal procedure)
Im taking it to a local shop who's worked on ZF 6HP26's before to have it rebuilt.
Stay tuned...
Stay tuned...
The following 7 users liked this post by stham:
AD2014 (04-01-2019),
Brewster411 (03-31-2019),
Don B (03-19-2019),
NDW (03-19-2019),
Panthro (04-11-2019),
and 2 others liked this post.
While the transmission is off getting rebuilt, Im working on a few other items on the to-do list.
Next up is Bosch SC coolant pump upgrade. Even with the bumper off this was a tedious install. the bigger pump is a snug fit in the stock location. My custom pigtail was easy enough to make though.
AD2014 (04-01-2019)
This pump is for the super charger cooling loop - this isnt the aux pump used for circulating fluid through the heater cores
Have always made the pig tails, or jumper harness adapters, to fit the bikes, as well as any car adaptations made.
That way you can always go back to stock, if things don't work out.
Many times your outsourced, save money part, is better than the stock one.
Then if it winds up saving you money to boot.
Life is good, if it was your own idea, even sweeter.
Transmission is back from the shop.
The culprit was a badly worn bushing on the E clutch drum. This excessive wear caused fluid pressure loss which in turn caused the noise and eventual slippage.
Since Im a bit paranoid about what kind of particulates may have been circulating around, I decided it would be best to flush the cooler & lines out. I bought 2 cans of this stuff and flushed the crap out of the cooler.
I still have to finish replacing the serp belts, tensioners and water pump. I hope to have the trans in and the car running next week.
