P0414 Error Code on a 2006 XJ8L
Old Sep 21, 2015 | 05:38 PM
Terry H's Avatar
Unhappy P0414 Error Code on a 2006 XJ8L
Does anybody know what causes a PO 414 error code and how to fix the problem so the code doesn't come back?
It has no effect on engine performance. My mechanic turned it off but it came back on. He said something about air input into the exhaust and it might be an air valve. We looked for a valve or solenoid. What and where could it be located? Could an air supply pipe to the exhaust be broken? If so, where in the world would I start looking for the problem? Help, Please.
Old Sep 21, 2015 | 07:10 PM
RJ237's Avatar
Try posting on the X350 forum. My XJ6 throws the code occasionally and it's for the secondary air pump which supplies air to the exhaust system under startup. You can check the thread below, but I'm not sure if it applies to your car.
https://www.jaguarforums.com/forum/x...-p0411-149884/
Old Sep 21, 2015 | 11:52 PM
Don B's Avatar
Hi Terry,
I have moved your thread from the forum for the X308 to the forum for the X350, which is the Jaguar factory project code for your 2006 XJ8L.
The P0414 Diagnostic Trouble Code doesn't show up in the DTC Summaries manual, but it shows up as P041400 in the Workshop Manual, which you can download in six sections free from this forum:
http://www.mediafire.com/download/md...f+contents.pdf
http://www.mediafire.com/download/aa...nformation.pdf
http://www.mediafire.com/download/n3...2.+Chassis.pdf
http://www.mediafire.com/download/9b...Powertrain.pdf
http://www.mediafire.com/download/0i...Electrical.pdf
http://www.mediafire.com/download/4j...+and+Paint.pdf
P041400 is defined on pdf page 1931 of the Powertrain section. It indicates a problem with the Secondary Air Injection Valve electrical circuit (not necessarily a problem with the valve itself). To diagnose the cause, the manual refers us to Pinpoint Test G528708p4, which begins on pdf page 1942.
You may also want to download the 2006 XJ Electrical Guide, which is available free here:
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
Cheers,
Don
Old Sep 22, 2015 | 01:10 AM
JagV8's Avatar
Just to confirm: the PO is P0 (people often say Oh for zero) and the final 00 of the 6-character code are commonly dropped, leaving 4 chars.
Old Sep 22, 2015 | 08:54 AM
Don B's Avatar
Thanks for bringing this up, JagV8. I had intended to and forgot. I have revised the thread title accordingly.
Cheers,
Don
Old Jul 1, 2017 | 08:05 PM
PatrickO's Avatar
Was the P0414 ever resolved?
Old Jul 2, 2017 | 06:01 AM
Partick the Cat's Avatar
See first post in DTC Code P0414
Old Jul 4, 2017 | 05:48 PM
06-XJR's Avatar
See also https://www.obd-codes.com/p0414
Bcrary3
Feb 21, 2023 04:29 AM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
tonyforman
Sep 10, 2015 07:23 PM
SCMike
Sep 9, 2015 09:30 AM
Bigvettefreak
Sep 6, 2015 04:27 PM
