Park brake missing cable?
Old Nov 5, 2019 | 04:22 PM
misplaced1954's Avatar
Default Park brake missing cable?
Hi I just bought this as I described in my introduction. I have several problems number one I get a park brake error I can hear the motor run I checked the cables they are free and the levers are free on the calipers. However on the driver side the cable comes from the lever on the caliper up to a certain point and there is a end on the cable but it's not hooked to anything on the passenger side the cable runs all the way across to the driver side wheel and then up to the motor and hooks into the motor I have no idea where the cable is that supposed to hook to the driver side rear can anybody help me where this is supposed to hook onto or if I am missing a cable I see no where to hook this thanks in advance
Old Nov 5, 2019 | 09:58 PM
Wingrider's Avatar
There is a copy of the shop manual on this site, i had already purchased a disk before finding out.
Old Nov 6, 2019 | 10:51 AM
Default Still no help
The shop manual shows the cable on the left and right side and the motor and the module however my cable on the left side driver side is not hooked to anything and I see no where to hook it is that just the way it's supposed to be? I can hear the motor run to apply to cable but get the error message any help appreciated
Old Nov 6, 2019 | 10:59 AM
JX350's Avatar
It might be helpful if you uploaded a photo of what you are seeing. I'm sure someone can then help direct you as to where the cable needs to be connected.
Thanks,
Chris
Old Nov 6, 2019 | 12:24 PM
Default Pic
Both cable side by side
Cable end opposite end of cable that connects to caliper hooked to nothing
Here are two pictures the first one is the end of the cable away from the caliper the second one shows the other cable alongside of it going to the right side
Old Nov 6, 2019 | 12:55 PM
jackra_1's Avatar
This is a pic of my lhs rear wheel parking brake lever and attached cable. Mine is a 2005 XJR so not sure whether mine would be the same as yours.
In any event there should be a lever on the parking brake I would think.
Old Nov 6, 2019 | 12:58 PM
Default Pic
I have cables on both sides they are both connected to the levers on each of the calipers my problem is the other end of the cable witch hooks onto nothing the one on the passenger side does go from the caliper all the way to the motor under the trunk
Old Nov 6, 2019 | 01:06 PM
jackra_1's Avatar
Ok now I understand.
Old Nov 6, 2019 | 01:30 PM
jackra_1's Avatar
Ok do you have Brembo brakes?
According to my workshop manual if you do not you only have the one handbrake caliper.
Old Nov 6, 2019 | 02:26 PM
Default One caliper
Thank you I have just regular brakes I believe nothing is Fancy on this car I can hear the motor run when I pull up on the parking brake lever but it's not moving the cable down by the caliper. And I get the error message park brake malfunction any ideas that does not look like it's very easy to get to the motor if that's the problem
Old Nov 6, 2019 | 02:34 PM
jackra_1's Avatar
Looks like there is something wrong with either the motor or the cable connection to the motor.
It really does not look easy to get to I agree.
Old Nov 6, 2019 | 03:07 PM
JX350's Avatar
Yes it looks like the cables are not being pulled and therefore tightened to engage the parking brake.
Old Nov 6, 2019 | 03:12 PM
Default Thanks
Well it looks like I'm going to find out how hard it is to get that out I think there is something wrong in the motor assembly it's not moving the cable in or out even though it does run
Old Nov 6, 2019 | 05:41 PM
Wingrider's Avatar
Looks like you found one of the reasons it was for sale, hopefully the only one
Both my XJ8's had issues when purchased, just like most anything used does.
Couple grand to put each one right, and have cars that look & run great.
jagstuart
Sep 13, 2018 09:53 AM
Elkulichi916
May 13, 2017 06:52 PM
Beav
Oct 28, 2014 11:23 AM
Adam Lueb
Oct 22, 2011 07:54 PM
dustedu5
Mar 13, 2009 09:23 PM
